egr delete
Old Mar 7, 2011 | 11:40 AM
BigRig515's Avatar
Default egr delete
iv seen alot of guys on here saying stuff about egr deletes and im just wondering what it is and what the egr does ?
Old Mar 7, 2011 | 02:40 PM
MUDSTROKIN''s Avatar
Exhaust Gas Recirculation. Puts your exhaust back into your intake. So your truck is pretty much eating its own Chit. And the EGR cooler cools the gasses before they enter your intake. The cooler often ruptures which leads to headgasket failure. My suggestion is delete it
Old Mar 7, 2011 | 03:57 PM
BigRig515's Avatar
thank ya and im lookin in to it
Old Mar 8, 2011 | 12:56 PM
Mdub707's Avatar
Yep, just keep reading around. This topic gets discussed on almost a daily basis. Lots of good info here already!
Old Mar 8, 2011 | 04:05 PM
BigRig515's Avatar
is there a specific one you would suggest ?
Old Mar 8, 2011 | 04:29 PM
crzycummins's Avatar
river city diesel...bulletproof diesel...sinister mfg...bd diesel, theres a bunch out there.
Old Mar 9, 2011 | 10:07 AM
BigRig515's Avatar
is this something i can do or does it need to be done by a shop ?
Old Mar 9, 2011 | 10:17 AM
Mdub707's Avatar
Depends how mechanically inclinded you are. It's really not a tough job at all, it is however, time consuming. Plan a FULL day to do it. More time will be needed if you choose to have your intake manifold hot-tanked or cleaned in some sort of way. Not a necessity, but if you're already in there....
It's really pretty simple job though. You may want an extra set of hands for a few parts, like removing the bolts on the up-pipe. Nice to have someone under the truck holding wrench or ratched, with someone up on top of motor holding the other end.
Old Mar 9, 2011 | 12:23 PM
ranger518's Avatar
If I was you and did a egr delete and your try k has any kind of millage on it and if you don't have a coolant filter I would replace the oil cooler with the new stainless steel oil screen you are over half way there when you do a egr delete and you wont ever need to worrey about it again if you put a coolant filter on.
Old Mar 9, 2011 | 05:42 PM
stone's Avatar
I agree with ranger, and while ur at it pull the ipr valve out n replace the screen on it.
