new lift pump?
Old Mar 6, 2011 | 05:21 PM
FastLaneDriver's Avatar
Default new lift pump?
I just bought a 2001 dodge 24v and was wanting to put bigger injectors in it The guy before put a heavy duty bd diesel lift pump rated for 15-18 psi i was wondering if i need a new lift pump before i get some injectors? BTW i was lookin at the big dawg 150hp injectors.
Old Mar 6, 2011 | 05:35 PM
RAW's Avatar
RAW
IS there anything else done to your truck? Any type of fueling box/programmer? How about a fuel pressure gauge? They are a must for these trucks, you never want less then 10 PSI at your VP44 or you run the risk of burning out the electronics. As long as you don't go under 10 PSI, the 150's will be fine. Without a fueling box/programmer, I doubt you will.
Old Mar 6, 2011 | 11:33 PM
01quadcab's Avatar
I have not heard much good on the bd lift pump. I would get a fass system. I would not go with that big of injector if you still have factory turbo. I would say a set of gauges and a programmer would be better suited before injectors.
Old Mar 7, 2011 | 02:25 PM
i got a set of gauges i got the pyro trans boost and just got the fuel pressure i also have and superchip that came with the truck nad a stage 2 afe cold air in it.if not injectors which chip would you suggest that i get or is the one i got a good chip? i dont know much about it as it came with the truck
Old Mar 7, 2011 | 02:52 PM
chad83181's Avatar
I would Buy a Smarty S-03 build it code reader.The Smarty has the potential to produce 140 hp with other supporting mods. You will like it better then the superchips. After that you might wanna try A EJWA or a Edge comp box especially if your planning on going bigger on injectors. I wouldn't wanna run more than 100 sticks with stock turbo,finding a HX35 and swapping out the HY35 will make some difference and help out EGT's
Old Mar 7, 2011 | 11:14 PM
01quadcab's Avatar
get an edge drag comp. the smarty doesn't add much hp to a vp truck compared to what they add to a common rail truck. I would sell the superchip the add a little but nothing like a comp.
Old Mar 9, 2011 | 08:43 PM
jsdidrick's Avatar
Default In need of your expertise again
99 Dodgeram 2500 cummins with worthless lift pump. I tow a 5ver 27' 8500 to 13000.
Should i just go to the in tank pump or do you think I should upgrade the lift pump.
Thanks again for the help.
Old Mar 10, 2011 | 08:09 AM
Default Re: new lift pump?
Intank pump is junk. Your best options are Raptor, Airdog, Fass or Fass HPFP.
Sent from my DROID2
Old Mar 10, 2011 | 08:29 AM
chad83181's Avatar
X2 What Luke said
HeavyChevy95
Dec 21, 2016 10:36 PM
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
