pmd removal ?
Old Mar 6, 2011 | 05:17 PM
muderxtreme's Avatar
Default pmd removal ?
Does anyone know if you have to remove the intake to get the pmd off the side of the injection pump. I'm relocating the one on my 94 6.5td.
Old Mar 6, 2011 | 06:50 PM
Woody35's Avatar
yes you do
Old Mar 6, 2011 | 07:10 PM
ok thanks
Old Mar 6, 2011 | 09:26 PM
Paintballrepins's Avatar
Are you relocating or installing a new one? I know you said relocating, but if you are installing a new one, you don't have to remove the old one. Just making sure.
Old Mar 6, 2011 | 09:39 PM
Crazy's Avatar
And if you trying replace one giving you problems leave it there get new one trying remove old one giving problems will not fix it
Old Mar 7, 2011 | 11:07 AM
The one I have is fine, I was just going to relocate it for preventative maint. That and I had a bit of free time
So I just got the stock one off of the pump without removing the intake or anything. A little bit of finagleing and shortening of an alen wrench and a few cuss words and I got it out. So it is possible
Last edited by muderxtreme; Mar 7, 2011 at 11:07 AM. Reason: Automerged Doublepost
Old Mar 10, 2011 | 12:04 AM
alright so i relocated the pmd, mounted it in the grill under the turn signal and theres alot of airflow there but the pmd is getting hot. when you guys bumper mounted it did you use a heat sink or anything for additional cooling? any advice?
Old Mar 10, 2011 | 03:48 PM
99crew's Avatar
Pretty sure you will need a heatsink even outside the engine compartment.
Old Mar 10, 2011 | 08:55 PM
Crazy's Avatar
if the PMD has move from the pump it going to need heat sink or less you want to make it paper wight
Old Mar 11, 2011 | 12:26 AM
Ya know that did cross my mind, I need somethin in the office. I mounted it to a homemade heatsink between the drivers side battery and the core support. There's a hole there where they used to mount round headlights and it flows enough air through that to cool the heatsink. it never gets over ambient temp now
