Help......code po216????
Old Mar 6, 2011 | 03:30 PM
clyoung12's Avatar
Default Help......code po216????
what do I need to do to fix this??? Do I need to put on a new ip or is there another way that I can fix this?????
Old Mar 6, 2011 | 10:01 PM
Crazy's Avatar
i have been running that code for 8 yrs i found out my pump was turn to far to right the wrong way
but the code is death code for a pump is it putting you in limp mode or what have you done to your truck latey before got the code
Old Mar 7, 2011 | 05:31 PM
clyoung12's Avatar
I had a coolant leak behind the timing cover. had to pull front of motor apart to replace two small gaskets and loosened pump to get cover off. So what your saying is that i need to roll pump counter clockwise to correct. I thought I put it back in the same spot .
Old Mar 7, 2011 | 05:44 PM
Woody35's Avatar
maybe you didnt tighten the set screws all the way and its slowly turning?
Old Mar 7, 2011 | 06:18 PM
clyoung12's Avatar
tried moving pump with pry bar it is tight. if i turn it counter clockwise will this reslove issue.
Old Mar 7, 2011 | 08:54 PM
Crazy's Avatar
put the pump at 12 o clock if anything you want it bump just litt to driver side you you really need put on computer to set it
dwmeehan
Sep 6, 2015 04:20 PM
Saams69
Jul 20, 2015 11:21 PM
flash7210
Jul 5, 2015 09:25 AM
robbyS
Apr 16, 2015 02:22 PM
Backhoeman
Jan 3, 2015 12:53 PM
