injector lines.
Old Mar 6, 2011 | 01:26 PM
coalrollin06's Avatar
Default injector lines.
This is for the people that have installed injectors or nozzles on their CR 5.9. i am looking to instal some in my truck but was wondering how other peoples luck has beeen with reuseing the stock injector lines and quill tubes?{ connection from in jector line through head to the injector} the stock lines are supossed to be one time use. since they mushroom to a certain contact area on the quill tube when connected,, im not sayin they cant be reused just that proper procedure is to replace rather than reuse. its the same case with the quill tubes. they make hi-flow tubes just cureious how it has worked for others and if you have replaced yours what brand/ size/etc you have used. any info would be appreciated i would hate to re use mine and have a high pressure fuel leak under my hood that would be a bad thing...
Old Mar 6, 2011 | 05:46 PM
K80's Avatar
K80
When I did my injectors I disconected the rail from the cp3 feed line, and unscrewed the lines from the connector tubes. That way you can pull the rail and feed lines out as one piece. They are reusable, be carefull with them and don't kink them.
Old Mar 7, 2011 | 08:24 AM
dangerous1965's Avatar
As long as they are not damaged you can reuse as many times as you want! Proper torque sequence +3 is all you need!
Old Mar 7, 2011 | 07:50 PM
ok guys thanks for the input.
Old Mar 7, 2011 | 09:43 PM
fast_stang_88's Avatar
just make sure the tip is nice and smooth and doesn't have a lip or edge on it. Plus I 2nd what dangerous1965 said, torque and 3# more.
Old Mar 7, 2011 | 10:25 PM
harry22's Avatar
3 as in 3 flats????
Old Mar 8, 2011 | 12:45 PM
yeah do you mean plus 3 degrees like torque plus a 3 degree angel oras harry 22 said 3 flats
Old Mar 21, 2011 | 01:30 PM
steved's Avatar
Probably means to triple check them...I simply snugged mine down by hand.
