DV replacement
Old Mar 6, 2011 | 06:18 PM
tower_ofpower's Avatar
Default DV replacement
ordered a new set of DV's. the repair manual says to replace the copper delivery valve washer, the new set of DV's only came with the o rings. is this something i NEED? or could it be re-used? every place i've seen only mentions o-rings
just found Whit's write up on DV replacement and it explains everything about the o-ring to copper washer difference. incase whit comes by this, Thank you
Last edited by tower_ofpower; Mar 6, 2011 at 06:18 PM. Reason: Automerged Doublepost
Old Mar 6, 2011 | 08:07 PM
justin c's Avatar
do yourself a favor use lots of grease.. (i know someone is gunna chime in here and say that im wrong but yet again my truck still makes more hp then theres so i must be doing somthing right) anyways the grease helps when u torgh the dv holders back down (assuming u are torghing them) even if u dont it will halp when u tighten them just like when u buy arp studs it comes with grease and that is why hope that helps u a little
Old Mar 6, 2011 | 08:36 PM
BRE's Avatar
BRE
A little full of ourselves here?
Old Mar 7, 2011 | 11:06 AM
94 12valve's Avatar
judging by some other posts and this one ... yes
Old Mar 7, 2011 | 12:13 PM
justin c's Avatar
not at all just sayin that im giving advice and then there is always someone that has somthing negative to say and USUALLY its the same guy that has 325hp and believes he has 600hp and drives around blowin smoke .. sry im used to a whole different group of people in a dif forum and we all get eachothers sence of humor.. im not trying to sound like a dick or whatever so please dont take it like that
Old Mar 8, 2011 | 10:09 PM
1978skidootnt's Avatar
Well you sounded dickish here. But i understand what you are saying the group you normally would laugh and call you on it. Anyway as for advise I'm not sure grease would be a good idea it's sticky and goopy and gets evey were what about new engine oil? I'm learning here so take or leave my thoughts it's up to you.
Old Mar 9, 2011 | 05:32 PM
repair manual says 90 weight gear oil. at any rate, thats not what i was curious about. its been taken care of thank you for your suggestions.
May 31, 2015 08:10 AM
makuloco2000
Feb 15, 2015 02:31 PM
Lawrence D. Sanders Sr
Jan 23, 2015 12:47 PM
South Texas Goat
Dec 30, 2014 11:44 AM
motormayhem
Nov 16, 2014 02:13 PM
