just draining me idea's?
Old Mar 5, 2011 | 09:57 PM
sean453's Avatar
Default just draining me idea's?
I have a 2006 f350 king ranch lwb I love this truck but as soon as it rolled 200,000 kms I've had nothing but problems do i cut my losses here?
in the last 2 weeks I have done
head gaskets
egr cooler
egr valve
2 injectors
map sensor
mass air flow sensor
all for a surging issue after 5 trips to the dealer the check engine lite is still on and i am over 10,000 dollars poorer
sypmtoms i have now are surging on moderate acceleration
and if the temperature drops below freezing (-26 ) degress celius the turbo lags 3-4 seconds then builds pressure 30 psi (no boost) until it shifts where it then drops to 15 psi then builds boost
current codes that come up are FICM and p0047 underboost over boost supercharger turbo charger.
any idea's or trade her off ...
Old Mar 7, 2011 | 08:19 AM
Mdub707's Avatar
FICM can be tested and fixed by you very easily. At least the testing will be no issue. Just do a google search on 6.0 powerstroke FICM test/repair. You will get lots of links. Very easy to test. The boost code is probably just a sooty turbo. Google for 6.0 powerstroke turbo recondition and you will find the link to "diesel technicians society" for cleaning your turbo, again, something you can do easy.
I hate when people throw money/parts at a truck without diagnosing it properly, and the worst part of this is your dealer is the one doing that.
Give us some more info about the truck, any mods, how does it drive, any smoke at all, if so what color? How is the truck used primarily, are you towing a lot? Just a DD? Short trips, long trips? Idle a lot?
Old Mar 7, 2011 | 02:38 PM
MUDSTROKIN''s Avatar
Cleaning the turbo is pretty simple
Old Mar 7, 2011 | 06:22 PM
sean453's Avatar
So mods on my truck afe cold air intake straight pipe no smoke while I drive it used to have a bully dog but.after the head gasket I chucked it out cleared the codes and it s been good so.far went to another shop and they said the.Ficm is.fine the.turbo has.been cleaned twice by the dealer or.I should say I paid twice for it
Old Mar 7, 2011 | 07:36 PM
Jamen89's Avatar
wanna sell your bully dog?
Old Mar 8, 2011 | 12:46 AM
sean453's Avatar
so i have a video of what it was doing last night but can't seem to upload it let me know if you want it to help me out .. thanks guys
i'll give this a shot
Old Mar 8, 2011 | 08:49 AM
I'll sell you an edge
Old Mar 8, 2011 | 01:04 PM
Mdub707's Avatar
If the FICM is fine, what voltage readings did you get? My guess is you didn't test it yourself. I would, it literally takes 5 minutes a buddy and a multimeter. You could cut this to 3 minutes if you skipped drinking a beer. VERY easy to do. I would do this first.
I find it hard to trust anything your dealer is telling you especially after that list of parts you've had replaced and still haven't cured the initial problem.
Test, Verify, Repair.
I will watch the video when I get home later.
363coupe
Nov 4, 2015 09:41 AM
Duramax2323
Chevy/GMC Duramax 01-04 LB7
Mar 9, 2015 04:34 PM
carid
Diesel Bombers Sponsors
Dec 16, 2014 05:16 AM
UniqueCopy
Dec 14, 2014 11:37 AM
txbiker
Jeep Liberty
Oct 27, 2014 10:36 AM
