broken "throttle" spring
Old Mar 4, 2011 | 07:36 PM
tower_ofpower's Avatar
Default broken "throttle" spring
the truck is a 98 12v with the 215 pump. the truck has a broken spring on the lower lever tied to the throttle linkage. from what i can tell it isnt a throttle return and its located towards the bottom of the pump. the truck has stalling issues and we've sunk a good bit of money into it and i'd hate for a simple spring to solve the problem hah just wondering the function, always assumed it had something to do with the cruise
Old Mar 4, 2011 | 07:46 PM
thanks to CumminsBronco, he posted a picture of the P pump for his build which was perfect to demonstrate what i was talking about.
Attached Thumbnails broken "throttle" spring-user31959_pic11981_1299261966.jpg
Old Mar 6, 2011 | 05:45 PM
bump? still lost here fellas
Old Mar 13, 2011 | 06:58 PM
noizykrikit's Avatar
have you found out what was causing your truck to stall mine will idle just fine and when randomly will stall when put into drive and you start to take off and the more throttle you give it the more it bogs out and did you ever find out what that spring went to mine is broken also
Old Mar 14, 2011 | 03:27 PM
The truck developed a miss, we changed the delivery valve hoping it'd solve the miss, it sounded like a timing problem except on one cylinder. The delivery valves didn't solve the problem but it cured our stalling issues. Look into fuel pressure issues, whether it be the overflow valve or lift pump. Our 98 just went into the shop for a corroded wire to the lift pump. The lift pump wasn't working. And I had the parts guy look up that spring. He still hasn't gotten back to me.
Old Mar 15, 2011 | 07:38 PM
apparently that spring has no other function than tension, atleast thats what the dodge garage said. i think i'm going to look up a cummins dealer and give them a call.
Chadpando
Jun 25, 2015 04:00 AM
VIIISecondRide
Mar 20, 2015 01:48 PM
detroitdiesel idi
Jan 2, 2015 02:07 PM
Nov 7, 2014 05:40 PM
myago92
Oct 17, 2014 08:50 AM
