01 Dodge 3500 diagnostic port problem
Old Mar 4, 2011 | 06:58 PM
tech 2000's Avatar
Default 01 Dodge 3500 diagnostic port problem
The check engine light came on so I stopped into Auto Zone to get the codes read. After the guy hooked up the scanner and turned the switch on he said there was no power at the diagnostic port so the scanner wouldn't work. Is there a fuse for this port? Where do I need to be looking to find the problem? I tried cycling the ign. switch 3 times to read the codes through the odometer but that didn't work either. I did get the gauge cluster test to run by pushing the trip odometer and turning the ign. switch on, that checked out ok. Thanks.
Old Mar 5, 2011 | 07:33 PM
Red_Rattler's Avatar
High Tech Redneck
Yep there is. Gonna have to take a test light and with the key on prob all the fuses till you find the bad one
burndiesel
10
Feb 7, 2023 01:15 AM
Jet A Fuel
For Sale
Aug 16, 2015 04:44 AM
thurobred1320
May 5, 2015 09:26 PM
vaio45
Dec 27, 2014 06:04 PM
jstoshick
For Sale
Oct 2, 2014 10:24 PM
