Need to clock my turbo - frozen up?
Old Mar 4, 2011 | 02:21 PM
F350Fummins's Avatar
Question Need to clock my turbo - frozen up?
I got a 92 ctd engine and I flipped the manifold so it would clear, need to reclock the turbo but it won't budge. Unloosened the 4 bolts holding it in position but it won't budge at all. Any input greatly appreciated.
Old Mar 6, 2011 | 12:02 PM
thumpertrev's Avatar
They dont just fall off after you unbolt them. Gotta beat on it a little.
Old Mar 6, 2011 | 02:12 PM
cougar's Avatar
Penetrating oil, patience, and a BIG dead blow hammer. A torch may also become necessary.
Old Mar 6, 2011 | 02:17 PM
RAW's Avatar
RAW
When hitting it with a hammer, make sure the bolts are only about a half turn loose. If they are too loose, and the hammer is too aggressive, the turbine could hit and bend it's fins on the inside of the exh. housing.
Old Mar 6, 2011 | 06:43 PM
beat on it for a while today didn't do much guess ill try just nocking the whole housing off and replace it with a 16 cm while I'm in there
Old Mar 7, 2011 | 08:12 AM
Levi Miller's Avatar
man i just went through 3 turbos in a row dont ask why butt you have to have patience with these things lots of penetrating oil and patience will get the job done unless some one pulled a prank and tack welded it to the manifold
Old Mar 7, 2011 | 10:27 PM
ha that would suck man think heat is the trick to er
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
GreenDieselF
Oct 20, 2014 02:05 PM
