Fuel Pump
Old Mar 4, 2011 | 10:02 AM
01cumminsrollingcoal's Avatar
Default Fuel Pump
I have a Holley 14 psi lift pump from NAPA on my 01 cummins and it feeds enough fuel for my 125hp injectors and EDGE comp box but im thinking about stacking the EDGE with a TST box.
Would that lift pump plus the stock pump be able to run those things?
Old Mar 4, 2011 | 10:10 AM
RAW's Avatar
RAW
What do you mean by plus the stock pump? Are you thinking running them in parallel or series? I ran a stock intank pump in series with a Car Quest block mounted pump for a little while. The idle PSI was way too high for my liking though, 31PSI. In parallel, you MIGHT be ok if one of the pumps is regulated.
Old Mar 4, 2011 | 10:25 AM
I ran mine in a series, the stock pump is on the tank and the Holley pump is on the same line just a little farther up. The way i set it up it will run the injectors and comp box and hasnt starved it for fuel.
Old Mar 4, 2011 | 11:10 AM
RAW's Avatar
RAW
What kind of fuel pressure do you have now? At idle and WOT?
Old Mar 4, 2011 | 01:26 PM
99 psi but my gauge is wired wrong so idk
Old Mar 4, 2011 | 02:38 PM
KillStroker's Avatar
wow
Old Mar 4, 2011 | 02:43 PM
Farmboy 2.0's Avatar
get a raptor 150 set it at 19 psi at a idle and call it good
Old Mar 4, 2011 | 02:55 PM
1st_gen_puller's Avatar
Mines set right around 21-23 idle... but i run some pretty harsh conditions... it will sink down to around 116 lowest wide open throttle full boost loaded towing... on older filters.. it wont move with new filters..
Old Mar 4, 2011 | 07:39 PM
RAW's Avatar
RAW
If you don't know your pressure, are you sure your not starving it? Just because it doesn't buck and kick doesn't mean its getting the minimum 10PSI to keep the electronics cool. I'd suggest getting the gauge fixed, then try other things.
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
HardLuck
Jun 24, 2015 08:04 AM
bud0994
9
Jun 8, 2015 06:15 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
Gm3500
May 7, 2015 11:01 AM
