Two questions I need answered
Old Mar 4, 2011 | 09:49 AM
NCFPD's Avatar
Default Two questions I need answered
Ok so can. Any one tell me how much the getrag will take power wise with just pump tuning I don't wanna break any thing also turning the pump up smoke screw and diaphram only just need a lil more power will it kill my fuel millageand what kinda Milage are you guys seeing with pump tuning
Old Mar 4, 2011 | 12:24 PM
kansas_first_gen's Avatar
You will eat your clutch before you tear that tranny up. Usually when the getrags blow up is when they get caught in between two gears and bust the synchronizers. This is due to the cast aluminum shift forks that wear out faster than you can replace them. If the getrag still shifts crisply don't worry about it. If you shell it, swap in an nv4500, pretty easy upgrade. If you just turn your pump up you will be fine. My dad tore up two rear ends that had the getrag in front of them. If you turn your pump up to about a 1-1.5 turns to max and run a ground fuel pin, expect 14-16mpg with 4.10s and 16-18mpg with 3.55s. If you don't run a ground pin and keep your foot out of it, you will see a little better mpg. Make sure you have a 4 in dp and big air filter and a pyro gauge before you even touch that pump.
Old Mar 4, 2011 | 12:59 PM
NCFPD's Avatar
Were can I get a down pipe from
So is that shift fork something to be concerned about is there an up grade fork
Old Mar 4, 2011 | 01:38 PM
source automotive for the dp
don't worry about the shift forks..if you have trouble shifting into first or reverse, pop the top off and see if they are worn.
If you are real rambunctious, pull the forks out and machine some copies out of billet. That is what I was gonna do but you can buy replacements for like 70 bucks.
[color=grey][size=-2]
Last edited by kansas_first_gen; Mar 4, 2011 at 01:39 PM. Reason: Automerged Doublepost
Old Mar 4, 2011 | 04:13 PM
NCFPD's Avatar
do you have to pull the trans to replace them
carid
Diesel Bombers Sponsors
11
May 21, 2015 09:57 AM
Mar 20, 2015 08:20 AM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
