Can it be done? Pro's N Con's?
Old Mar 4, 2011 | 04:49 AM
04cumminsbeast's Avatar
Default Can it be done? Pro's N Con's?
i was wondering if it is possible to P-pump a 2004 Common Rail? If so what are the pro's N con's?
thanks guys
Old Mar 4, 2011 | 06:37 AM
sabortooth's Avatar
I'm not sure what you mean by p-pump, but i hope you are talking a propane conversion, which I am curious about myself. It is almost to the point where peanut oil from the grocery store is cheaper than diesel. I would like to see a natural gas conversion.
Old Mar 4, 2011 | 08:59 AM
1badcummins's Avatar
There is one company that makes a conversion kit but it's so pricy I'd just modify the common rail stuff less smoke more pressure and better mileage. Plus it's tunable were if you were to p-pump it it would just run however the pump is set up.
Old Mar 4, 2011 | 09:00 AM
http://www.phdperformance.com/conversion.html
Old Mar 4, 2011 | 09:03 AM
johnfak's Avatar
It's the mechanic injection pump for the 12v trucks. A lot of pullers and high hp 24v 2nd gen trucks do away with the vp44 in order to get the power and reliability
Old Mar 4, 2011 | 10:26 AM
dieselward's Avatar
Yep...I see no reason to p-pump a CR truck unless you were doing nothing but hardcore drag/pulling and knew what you were tuning it for.
dw
Old Mar 4, 2011 | 11:30 AM
BriteWhiteRam's Avatar
dw
a CR can be set up just as well as a p-pump for 1000hp and you could still drive to the store and get your groceries with it
Old Mar 4, 2011 | 08:01 PM
alight thanks guys. i wanna build about 800hp in the near future was kinda looking into all options, cuz i know i will need to run dual cp3's for that much power but was wonder what is gonna cost less and be better in the long run?
HOLY COW!!!! $$4700 and thats without pump or core charges! dam!!!
Last edited by 04cumminsbeast; Mar 4, 2011 at 08:01 PM. Reason: Automerged Doublepost
torque monsters diesel
Mar 1, 2015 05:20 PM
