white smoke when engine is cold
Old Mar 3, 2011 | 08:41 PM
bigginwelds's Avatar
Default white smoke when engine is cold
hi my uncle has an 06 6.0 and when he starts it it has no power and blows white smoke until it gets up to running temp after that it runs great. any suggestions what it could be??
Old Mar 3, 2011 | 08:53 PM
crzycummins's Avatar
Ficm?
Old Mar 3, 2011 | 09:10 PM
thats a start thanks for the input, im a dodge man and have never popped the hood on a ford. this should be iteresting
Old Mar 4, 2011 | 07:39 AM
Mdub707's Avatar
Hard to say, could be a number of things, try reading codes and try testing the FICM, it's VERY easy to do and will at least eliminate that as a possibility if it tests ok.
Old Mar 4, 2011 | 10:35 AM
Miller Diesel's Avatar
sounds like the problem i had with my high pressure oil rail plugs. theres a little seal on them that blows. my truck would blow white bluish smoke for the first 3-4 mins until it warmed up and had no power. also hard to start at times. eventualy got worse and wouldnt start.
Old Mar 4, 2011 | 10:38 AM
jimrd's Avatar
I would monitor the fluid levels to make sure not antifreeze....
or may be condensation in the pipe....
This morning started then a few minutes later start seeing smoke out of pipe..
If the fluids are okay ...i would not worry about it
mattshow123
14
Mar 12, 2018 01:41 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
sandlappa
Aug 23, 2015 09:20 PM
Oltian.
Diesel Bombers Sponsors
Feb 24, 2015 10:07 PM
zoomer10h
Feb 6, 2015 01:38 AM
