chevy nv4500 to 1991 cummins
Old Mar 2, 2011 | 10:42 PM
chevycummins444's Avatar
Default chevy nv4500 to 1991 cummins
does anyone know what all has to be done to put a chevy nv4500 to a 91 cummins. i know the input shafts are different and will interchange but what else. special bellhousing?if you have any info let me know
Old Mar 3, 2011 | 07:07 AM
KD93's Avatar
Do a search on here and I'm sure you'll come up with something. You might also want to cruise the other forums out in the ether. Dieseltruckresource is particularly abundant with good info, although they're by no means the only one.
Old Mar 3, 2011 | 09:53 PM
Chevy72's Avatar
try nv4500.com they have all the info you need about the nv I don't think you can use the chevy trans but check the site to be sure.
Old Mar 5, 2011 | 09:55 AM
SteveinAz's Avatar
95 and earlier chevy stuff is not compatible. Bolt pattern is different on the front of the case. First gear is different. Shifter is different. 96 and later can be converted, but by the time you purchase the conversion parts you may as well find what you really need.
DieselDan370
Diesel Engine Conversions
Aug 23, 2016 02:24 PM
David90
Sep 16, 2015 12:48 PM
Hayden_Rake
Jul 9, 2015 01:55 PM
Big Sal
Apr 19, 2015 03:59 PM
mtedrick4
Oct 13, 2014 09:25 PM
