NV5600 How much oil?
Old Mar 2, 2011 | 09:14 PM
haulitrite's Avatar
Default NV5600 How much oil?
I am changing the oil in my trans. Some people say to over fill by a little, some say to put a extra quart in.
What is the best way to go?
Thanks.
Old Mar 3, 2011 | 09:45 PM
coors_man_2005's Avatar
i would just pull the bolt on the side fill till it runs out extra quart woundnt hurt a bit
Old Mar 6, 2011 | 10:12 PM
harry22's Avatar
9.6 pints, 1 quart=2 pints
Old Mar 8, 2011 | 09:12 PM
mopo824's Avatar
calls for 4.8 quarts i put 6 to cover everything also use synchromesh MTF amsoil makes it and Royal Purple does too its called syncromax
Old Mar 9, 2011 | 12:07 PM
dieseldude03's Avatar
I do 6 quarts in mine but you can barely get 5 in through the fill port on the side. You either have to park sideways in a ditch (preferably one you can drive back out of) or pull the shifter from the top of the trans (not hard to do at all). I also use the Amsoil Syncromesh stuff.
This has been recommended to be by several people, including a good friend who is the local Cummins/Dodge tech. Reason is, when pulling a steep hill on mountain highways and such, the trans oil will flow to the back of the trans and leave the front bearings dry. With 6-quarts in, this won't happen and it does NOT create any over-fill problems.
Old Mar 9, 2011 | 12:31 PM
Farmboy 2.0's Avatar
I do 6 quarts in mine when I change it
Old Mar 14, 2011 | 10:50 AM
steved's Avatar
If you don't pull the PTO covers, you can only get a little more than 4 quarts in on the refill...a lot hangs up in the "sump" in the bottom. I usually pull the cover, then soak up the excess with towels. Then it takes just shy of 5 quarts to refill.
Synchromesh is the fluid, but they are not all the same, and act differently in each NV5600. One may work better than another in your particular trans. Mine likes Redline the best...didn't shift for beans with RP SynchroMax, and Amsoil MTF shift quality was short lived. The only way you will know is to pick one, and use it a while...then try another if the first one didn't work well.
Overfilling has been debated...all I can tell you is that overfilling by a quart (before coolers) caused the oil to run hotter in my NV5600.
Old Mar 14, 2011 | 11:07 AM
bluedieselram's Avatar
iv always put 6 quarts in mine
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
coors_man_2005
Dec 15, 2014 10:23 AM
97f-250
Nov 23, 2014 08:08 PM
