Emission test ?
Old Mar 2, 2011 | 06:31 PM
Moparpower440's Avatar
Default Emission test ?
So I live in colorado And here your truck gets run on a dyno for the test. I'm wanting to put a set of sdx stage 2 injectors in but I have to be able to pass the test. I currently put the stock plate back in and tune it back down. But I don't want to have to switch injectors every year. So Would a valet switch help me out? If so can I make one by plumbing a small brass valve in, instead of the fancy electric solenoid?. Any other suggestions would be great.
Old Mar 2, 2011 | 07:11 PM
bluedieselram's Avatar
increase your airflow?larger diameter exhuast so the smoke is more spread out
Old Mar 2, 2011 | 07:19 PM
madmikeismad's Avatar
Put the fuel plate all the way back, and set the AFC to be a complete dog. If you make smoke then, I will shake your hand.
Also, make sure your pump/AFC look stock. I know some states check for that.
Old Mar 2, 2011 | 10:15 PM
Well I have 5 inch exhaust with a 6" tip and they clamp a funnel on it to direct the smoke through the opacity meter. Last time I tested it was at 27% opacity. The limit is 35 here and the truck made 167 hp at the wheels according to there dyno. Will the truck even move with the plate all the way back?
Old Mar 2, 2011 | 10:37 PM
Who cares, as long as it passes.
Old Mar 3, 2011 | 12:17 AM
1978skidootnt's Avatar
Yep pull all the fuel out every year to pass emissions then set it back where you really want it it's only a few hours every year.
Last edited by 1978skidootnt; Mar 3, 2011 at 12:17 AM. Reason: Automerged Doublepost
Old Mar 3, 2011 | 05:44 AM
pukie370's Avatar
just a thought, i had problems making power-smoke and it turned out to be my cylinoid on pump was not opeaning all the way. i wonder if you could just adjust arm to limit fuel.
Old Mar 3, 2011 | 06:39 AM
tower_ofpower's Avatar
Fuel plate does the same thing without causing *** for fuel mileage
Jul 30, 2015 10:30 AM
May 20, 2015 11:20 PM
Nov 20, 2014 11:20 AM
Oct 16, 2014 07:10 PM
Oct 11, 2014 06:25 AM
