International 4200 series 6.0L red engine light
Old Mar 2, 2011 | 05:07 PM
prison's Avatar
Default International 4200 series 6.0L red engine light
Hey guys we were changin the oil in a dump truck which is an international 4200 with a powerstroke 6.0 at school today (i didnt change the oil a friend did) and i went to start it and it threw a red engine light and the screen said oil/water. the oil pressure is around 63 which seems fine to me. No oil leaks that we could see but we ran out of time. any ideas?
thanks,
Erik
Old Mar 2, 2011 | 09:34 PM
Hegel122's Avatar
not to sure but can u pull the codes on the guage cluster like some of the newer internationals?? was the light on before you changed the oil??
Old Mar 3, 2011 | 12:01 AM
prison's Avatar
nope i drove it in and there were no lights. my teacher said somethin about the cruise control button and some light codes on the dash
Old Mar 3, 2011 | 06:25 PM
Hegel122's Avatar
yea turn the key to the on position parking brake on, hold the cruise on and the resume at the same time... then the codes will pop up... read the codes then find the manual and the manual will tell you wat the problem is... then to clear the codes turn ur left blinker on... then hold the cruise on and cruise set at the same time... and the parking brake has to be on again... sounds retarded but its actually the same thing as the MRAPS that international builds...
Old Mar 3, 2011 | 06:49 PM
prison's Avatar
wow i wish my truck had this. i fired it up twice today and the engine light never came back on. did fuel filter and pre filter then fired up. still no light so i got no idea what it was
Old Mar 5, 2011 | 04:55 PM
Hegel122's Avatar
if it only came on once then it prolly came on wen u first fired it up and it had no oil up top wich is my guess... other than that i dunno.. but the codes are nice... it shows the code u look it up and it says either exactly wat to change or it gives u choices then you troubleshoot... the new allisons we got does the same thing
Old Mar 5, 2011 | 05:01 PM
prison's Avatar
ya man it was weird. i wonder if somebody could write a program on our computers to do something like this. that'd be worth a buck or two
Old Mar 5, 2011 | 06:56 PM
Hegel122's Avatar
yea its a pretty kool thing but adds a **** ton of wires and relays and sensors... its wired into everything and ur guages have to be compatible also...
Old Mar 7, 2011 | 08:30 PM
white93's Avatar
Thats exactly what happens at work with every international on the lot. If it sees no oil pressure for more than 5 sec it throws the light and alarm on. It will also throw the code " lubricant pressure below desired level". Not a problem unless it doesn't ever build any pressure.
Old Mar 7, 2011 | 08:33 PM
prison's Avatar
I guess its better they beep at ya than not tell ya at all
burndiesel
10
Feb 7, 2023 01:15 AM
gauge1325
May 3, 2015 01:33 PM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
krinderhagen
Jan 15, 2015 12:07 AM
FELTONMICHAEL
Dec 28, 2014 01:09 PM
