1999 dodge ram no start
Old Mar 2, 2011 | 05:41 AM
taledennie's Avatar
Default 1999 dodge ram no start
ok long story but here goes nothin. started off driven done the expressway lost tranny fuction. got towed back home thought i had a bad tranny. went to push it into to the barn and it started and drove into the barn so i tried to see how far it would last. got about a 30 secounds of playin around in the driveway lost tranny function again. so i turned it off and started it back up and everything was fine again so it did the same thing again thought i had a wiring issue. so i checked for codes with an mt2500 and got no comm for data and codes kept changing. so i checked other modules and got the same thing. so i unplugged the pcm and tried again. i regained info from all modules exept trans. so i checked power and ground at the pcm all was good. so i ordered a pcm programmed for my truck. finnally got and plugged it in. now the truck wont start and the insturment cluster has no bus. if i unplug the pcm it starts and drive down the street with tranny in limp mode but wont start with new pcm. i put the old pcm in and it starts fine. im runnin out of ideas and could use some help.
thanks
Old Mar 2, 2011 | 07:40 AM
banditsdiesel's Avatar
sounds like the pcm you ordered wasnt programmed correctly. most likely not programmed to your vin right. i would send it back.
Old Mar 2, 2011 | 06:03 PM
taledennie's Avatar
i sent it back and got a second one with the same issue i was about to try dodge next.
Old Mar 6, 2011 | 06:07 PM
6btcummins's Avatar
try dodge. deffinitly a pcm issue one of my friends had the same problem.
PeteBug
Jun 11, 2015 12:16 PM
May 7, 2015 02:50 PM
Dec 29, 2014 10:20 AM
Nov 3, 2014 08:10 AM
Oct 24, 2014 02:50 PM
