Need help with identifying parts on block
Old Mar 1, 2011 | 06:04 PM
brianjbeach85's Avatar
Default Need help with identifying parts on block
Guys trying to figure out what the large black cylinder is on turbo side of block.. i think it is the transmission cooler.. but alittle help is greatly appreciated. In process of breaking down motor so trying to retain what i need to hold onto. I have a 2005 F250 im swapping this into and torqueshift has cooler drivin from tranny.. so im in luck if it is!
Old Mar 2, 2011 | 07:43 PM
bump... someone has to know what this thing is.. come on guys take 2 minutes and let me know
Old Mar 2, 2011 | 08:00 PM
mysterync's Avatar
Heat exchanger used to build heat in the trans. Great way to cause problems if you don't just trash it
Old Mar 2, 2011 | 08:02 PM
whats the process for plugging the holes up near pulleys and stuff?
Old Mar 2, 2011 | 08:04 PM
mysterync's Avatar
Holes near pulleys? You mean bypassing coolant lines? Cut them to fit, cut the metal lines and do some switching till it fits correctly.
Old Mar 2, 2011 | 08:17 PM
So basically reroute them back into the opening?
Old Mar 2, 2011 | 08:20 PM
mysterync's Avatar
Again, If your talking coolant lines, you bypass the cooler it's a very simple fix, run the one from the top, into the one at the bottom.
Old Mar 2, 2011 | 08:24 PM
yeah i am pretty sure its the transmission heat exchanger. it has 2 steel lines that run into it from bottom of black cylinder below turbo ...then what you described a coolant hose comming out of the block to cylinder.. then 1 back to block right below other coolant line. Thanks for input.. i will just bypass
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
Slim Whitey
Nov 8, 2014 09:41 PM
Sculpturesylvan
Oct 18, 2014 10:40 PM
Sculpturesylvan
Oct 18, 2014 10:19 PM
Oct 8, 2014 11:50 AM
