I Got A Little Problem
Old Mar 1, 2011 | 12:36 PM
SilverStallion's Avatar
Default I Got A Little Problem
i have the DTC "P0237 Turbocharger Boost Sensor A Circuit Low" and it will not clear. when i drive the engine wont get above 1200 rpm, but at idle i can rev it all the way to 3000 rpm. idk wtf the issue is and its beggining to **** me off. any input on how to fix or what the problem is?
Old Mar 1, 2011 | 09:08 PM
banditsdiesel's Avatar
change the map sensor its sounds like its bad. might wanna just check to see if its unplugged. also do you have a tunner on the truck
Old Mar 3, 2011 | 07:18 PM
72fj's Avatar
Default boost pressure senor problem.!!!
silver stallion install new psi sender and it will take care of power problem. boost sensor is located on intake cover.
burndiesel
10
Feb 7, 2023 01:15 AM
Jake9473
Jul 22, 2018 08:19 AM
jeremy01995
Sep 14, 2015 06:34 PM
thurobred1320
May 5, 2015 09:26 PM
Dadslb7
Dec 9, 2014 11:05 PM
