Speedo quit after installing BD speed eliminator
Old Mar 1, 2011 | 11:45 AM
01trailerpuller's Avatar
Default Speedo quit after installing BD speed eliminator
I installed a BD speed eliminator Sunday night so I could start doing some boosted launchs. The first time I went to use it I did a 10psi launch and the truck went into limp mode and through the normal codes the RAD throws. So I plugged in my smarty cleared the codes to to go home to see if I did something wrong and the speedo would not register on my dash or in my Edge. Also I have a BD Torqloc that quit working with the speedo. Is there a fuse or relay that runs the speedo? Also I believe that my torqloc is on the same relay (I did not install it). If anyone has any ideas how to fix my problem I am open to suggestions. I will not be able to remove the RAD until this weekend do to my schedule.
Old Mar 3, 2011 | 04:20 PM
I reconnected the wires that were bypased by the speed eliminator and my speedo came back. But the torqloc is not working and my edge is still not receiving speed info. I checked to make sure that the torqlock is getting power. Is there anyone out there that has delt with this or has an idea.
Dertyd
24
Jun 7, 2015 02:45 PM
Cutlass26
Mar 22, 2015 05:46 PM
