amount of electricity used to heat block
Old Feb 28, 2011 | 09:03 PM
doberdawg's Avatar
Default amount of electricity used to heat block
I started my truck today, first time since getting it. I had to plug in the block warmer in California weather!! Anyway, I am wondering 2 things: First in 40 - 60 degree weather how long does it need to be plugged in??? AND Secondly how much electricity does it use - I guess in kilowats?? Thanxxx
Old Feb 28, 2011 | 09:18 PM
Woody35's Avatar
a well functioning 6.2 wont need a block heater in 40-60 degree weather. if you really do need it you need to check your glowplug system to see if it is running up to snuff. for example my 6.5 that has less compression will start in the middle of a IL winter at o degrees without one and will barely make any smoke.
some people run them all night some people run them a few hours. it just depends on what is needed. the longer you run it im sure the shorter it's life will be but there not terribley hard to change. not really sure on electricity usage.
Old Feb 28, 2011 | 09:59 PM
Crazy's Avatar
i have to X2 on what Woody35 motor should not need the heater block
at 40 or 60 degrees you should not have to used block heater
Old Mar 1, 2011 | 01:05 AM
doberdawg's Avatar
It would not start w/o heating the block & the seller said it would start easily if I used it. I plugged it in for a few hours & It started instantly-?? My first diesel, & an accident-a fortunate one I hope.
auspot
Jun 30, 2015 05:57 AM
Jan 22, 2015 02:40 PM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
Slim Whitey
Nov 8, 2014 09:41 PM
Oct 8, 2014 11:50 AM
