1998.5 NOT cranking
Old Feb 28, 2011 | 06:32 PM
bigred98's Avatar
Default 1998.5 NOT cranking
I have a 1998 that is not cranking. Using my multimeter I tested all terminals of the realy and found that I have no ground on the control side of the relay. Does anyone know where this relay is grounded? Does it have its own ground to the frame or body or is it grounded through the ECM? I confirmed the bad ground buy running a jumper wire from the relay to the - on the battery and it started. The stater is new as well
Thanks for any help you guys can offer.
Old Feb 28, 2011 | 07:43 PM
turbostang7's Avatar
neutral safety switch?
Old Feb 28, 2011 | 08:21 PM
bigred98's Avatar
dont have a neutral safty switch used to be an automatic i converted it to manual
Old Feb 28, 2011 | 08:33 PM
was this right after the conversion? or did it just start doing this. a manual still has the safety switch in it, its just on the clutch pedal. i converted mine from a manual to an auto so i had to wire all that up. i would fill out your signature and give a little more detail as to what is going on with things like when it started, etc.
Old Feb 28, 2011 | 08:58 PM
bigred98's Avatar
it just started doing it i did a motor swap cuz it had the 53 block and it was doin it on and off and now it completely stopped cranking so there is no safety switch to hook up cuz i dont have to push the clutch in to start it. i think it is the ground for the starter relay cuz the other conectors for the relay have juice when suppost to but none to the ground but i an run the ground for the relay to the battery and start it that way
i just have to figure out where the ground goes to
Old Feb 28, 2011 | 09:11 PM
RAW's Avatar
RAW
Looks like it goes to the Park/Neutral Position Switch, and the PCM. PCM wire is a Black wire with White tracer, Connector C1, Pin 6. That's the best I can determine from the high quality Dodge schematic. Even an auto has a Park/Neutral switch.
Old Feb 28, 2011 | 09:29 PM
bigred98's Avatar
Alright ill have to trace some wires thanks for the help ill take anything I can get when it was converted it didn't have the problem and its been converted for 2 years now just started a couple days ago, just curious why did u switch from manual to auto usually its the other way around.
How do u like ur 65 sticks I got 50 sticks and a couple more up grades
Old Feb 28, 2011 | 09:44 PM
RAW's Avatar
RAW
Mine's been an auto since day one, actually.
I love my 65's, it was an amazing difference between stock and the 65's. Better starting, less smoke, more power, and better MPG'S!
Old Feb 28, 2011 | 09:48 PM
i went manual to auto for speed, want to go faster at the track, and it makes it easier for the wife to sit next to me while driving around
Old Feb 28, 2011 | 10:29 PM
bigred98's Avatar
Alright I shoulb be happy with the sticks I got plus I have htt turbo 62/74/14 fass edge comp box and s & b intake
RAWilliams what is the average mpg you are getting
