which one
Old Feb 28, 2011 | 12:36 AM
pngmotoman's Avatar
Question which one
Ok so i know there are always tons of threads about this and it is always the smarty that gets picked for the best programer but i can use that one.
When i did my manual swap the truck got reprogramed and they put a non stock dodge tune on it so now i cant use my smarty anymore. So i have to get a programer that hooks up to the motor. which would be the TST or Edge. or at least that is what i have found that i like so far.
Wondering which one you guys think is better?
Or if there is another one out there that is better then those two?
Old Feb 28, 2011 | 07:20 AM
K80's Avatar
K80
I have an Edge in mine and had zero problems with it. Called them up for the hot unlock, seemed like cool guys.
Old Feb 28, 2011 | 07:24 AM
cummins army's Avatar
i got edge and have no problems with it. i like the gauges it comes with too.
do you still have the smarty if you do how much
Old Feb 28, 2011 | 09:19 AM
pngmotoman's Avatar
sorry i already got rid of the smarty. i know that with the smarty it was really amazing power down low. I had a friend that had the edge and didnt have the low end like me. do you notice a big diffrence with the hot unlockon the low end?
Old Feb 28, 2011 | 09:26 AM
K80's Avatar
K80
The hot unlock makes good power but I only ran it once with it cuz when I went for 5th the clutch was on the floor and it was draining the rail at higher rpm. so my DD is goin in soon and I have to shop for a bigger CP3 to fuel it
Old Feb 28, 2011 | 09:42 AM
pngmotoman's Avatar
i have a southbend dd already in mine so hoping that will be good in that department. guess ill need to get a beter CP3 then if i would like to get the hot unlock
Old Feb 28, 2011 | 05:09 PM
CreeperSleeper's Avatar
I was back and forth between the Edge and the Quadzilla Adrenaline. I ended up with the Quadzilla and couldn't be happier. Awesome guys and an awesome product. When I get it dialed in completely, I want to go head to head with my uncles '05 with the Edge but I really think I made the better choice by far!
Old Mar 1, 2011 | 12:14 AM
pngmotoman's Avatar
sweet ill look into the adrenaline today. i totally forgot about that one hooking up like the other ones
Old Mar 1, 2011 | 08:38 PM
BriteWhiteRam's Avatar
The TST is one of the nastiest inline tuners you can get... it will out do the edge
So you have like an aftermarket ECM or what? I dont quite understand....
Old Mar 1, 2011 | 11:37 PM
pngmotoman's Avatar
i did the 6 speed swap on my truck and it stuck it in limp mode so i took it to a shop so they could reprogram it and they did but since it not a stock dodge tune the smarty couldnt read it. thats why i need one the actually hooks up under the hood
