thought I had a spare turbo...
Old Feb 27, 2011 | 01:15 PM
crazycooter's Avatar
Default thought I had a spare turbo...
I have a spare hx 35, but, when I went to throw a rebuild at it, I notice a couple of small fractures stemming from the inside of the exhaust housing. I am just looking for a bit of solid advice, on what I should do next, keeping in mind that I am on a budget, and my running turbo right now has some pretty serious shaft play in it. I think I am going to do just as good right now by finding a replacement hx35 housing, but I am at a loss as the where to find one...
Old Feb 27, 2011 | 01:17 PM
turbostang7's Avatar
put the one off yours on it. rebuild it and when it gets to that step just swap them out and install the rebuilt one!
Old Feb 27, 2011 | 04:20 PM
Cody Cummins's Avatar
possibility to tig weld the housing?
Old Feb 27, 2011 | 06:14 PM
Benjamin's Avatar
Bombardier
take the housing off the one on the truck and install it on the one off the truck, then install....
Old Feb 27, 2011 | 06:23 PM
I see what you are all saying, but maybe I want to put together something later like a compound... something to start with an hx35 and close with something like a k31, or even something really huge like an M24... tig welding isn't an option as the cracks are on the inside of the turbine wheel housing itself, and there are no gaurantees that the one I am running right now is not suffering the same problem. I fear this, because of the fact that I have my wastegate closed off completely, I am struggling to get all of 20 psi boost. I think I want to have a complete turbo to swap out in place of what I have right now, so I have a couple hour project, and will not end up with one of those hidden variable projects.
Old Feb 27, 2011 | 06:27 PM
Benjamin's Avatar
Bombardier
all exhaust housings are going to be cracked, it just depends on the severity of if it will cause issues or not. the best way to find out is to swap it out and see if the cracked housing will work or not.
Old Feb 27, 2011 | 06:28 PM
mysterync's Avatar
Benjamin is correct on this!
Old Feb 27, 2011 | 06:32 PM
Benjamin's Avatar
Bombardier
and BTW don't block the wastegete on the new one, that just makes the air hotter and the EGT's hotter and will cause the cracks to become a problem sooner than later.
Old Feb 27, 2011 | 07:38 PM
well then, I guess I can just put it together and give it a go, and settle for the upgrade later... or I might have just found an hx30w for $1.65? got to call FL in the morning
Old Feb 27, 2011 | 08:06 PM
turbo20psi's Avatar
The above statement been very ture.Has anyone had there exhaust housing HPC coated or somthing done to the housing to resist cracking? No matter what the temperture of the exhaust EGT? Sorry OP maybe something or someone can give some info on the crack housing issuse? I,m all ears!
High Performance Coatings - OEM Coating Technology
Last edited by turbo20psi; Feb 27, 2011 at 08:06 PM. Reason: Automerged Doublepost
