blow-by
Old Feb 27, 2011 | 07:38 AM
01dowork's Avatar
Default blow-by
what exactly is blow-by and what causes it. i think my 01 does it but not sure. i get a little oil on my floor out of that over flow or blow-by tube every night. any fixes. thanks
Old Feb 27, 2011 | 07:54 AM
RAW's Avatar
RAW
Blow-by is a combination of gases that collect in your crankcase, primarily cylinder gases. Not all compression and power stroke gases are sealed by the piston ring. A small amount leaks by every time the piston goes up. Essentially the gas blows-by the rings, therefor Blow-By. Ever engine has some, and as engines wear more blow-by is produced.
Vaporized oil is also in your blow-by, and is carried out the blow-by tube. Our trucks can with a catch can, more commonly known as the slobber can as is slobbers a little oil out every now and again. This can is removable, and can be poured out and cleaned as necessary. Optionally, you can ditch the bottle and run an extra piece of heater hose on the blow-by tube to redirect the slobber. Some send it straight down, others run the hose to the flywheel area to keep the slobber off the axle.
rollover
May 5, 2015 07:33 PM
EasTxOilfields
18
Apr 2, 2015 01:51 PM
jedder21
Mar 7, 2015 09:47 PM
Nov 10, 2014 08:10 AM
CumminsCrazed
Price Quote - Request A Price
Oct 13, 2014 02:35 PM
