WHATS A GOOD STACK FOR MY 04?
Old Feb 26, 2011 | 11:29 PM
04cumminsbeast's Avatar
Up WHATS A GOOD STACK FOR MY 04?
i am wanting to stack programmers on my truck soon and was wondering what you guys run. right now my truck has the edge 100hp box that stays under the hood. what do you guys think about that box with a bully dog triple dog download-er stackked? also what other supporting mods do i need?
Old Feb 27, 2011 | 01:22 AM
big bad diesel 416's Avatar
Site Sponsor
the smarty is a good one stacked with what IDK everyone is different
how much HP are ya looking for?
Old Feb 27, 2011 | 02:03 AM
700-800 in the end
Old Feb 27, 2011 | 02:05 AM
Site Sponsor
smarty edge?
Old Feb 28, 2011 | 09:36 PM
smarty edge what do you mean?
Old Feb 28, 2011 | 10:28 PM
BriteWhiteRam's Avatar
Run the edge and get a Smart S-06 as a programmer, You have to make sure that if you run the smarty with the edge you need to run the tunes on the smarty WITHOUT timing!!! otherwise your gona have a broken engine
Old Feb 28, 2011 | 11:13 PM
why without timing will it over advance it then and blow it?
what other mods do i need to do?
Old Mar 1, 2011 | 06:08 PM
If you run the smarty with timing you can hurt your brand new injectors, if you hear a lot of injector rattle then you are running too much timing, thats why its recommended to run the smarty with no timing added
If you havn't already your going to need to do something with your clutch or auto trans, running two tunes will more than likely hurt it
Oh and a liftpump like a FASS or Airdog II should also be on your list
Old Mar 1, 2011 | 06:16 PM
Farmboy 2.0's Avatar
You will need bigger injectors, a modded Cp3 or duals preferably duals, lift pump, head studs, trans work or clutch turbo or turbos. And run a smarty edge stack. But first you need a lift pump, and I would be head studs as well before you have a blown head gasket due to boost
Old Mar 2, 2011 | 05:17 PM
Alligator Vinny's Avatar
Site Sponsor - Alligator Performance
The Edge Juice with Attitude Smarty stack has worked great for me over the years. I have had my truck set up this way for 4 1/2 years now with no issues.
I am running the Silver 66 from Industrial Injections as a single turbo with Dual CP3's and a bunch of other goodies.
There is definitely an application for stacking programmers. I would say with a heavily modified truck it would be a huge benefit. With a relatively stock truck it would be a waste of time and money and could very likely hurt the truck rather than help it.
