12 valve build up Need input!
Old Feb 26, 2011 | 04:47 PM
brianjbeach85's Avatar
Default 12 valve build up Need input!
Hey guys,
I Got a 1996 12 valve building my list of mods. any input to this is greatly appreciated. Still new to cummins, so Do i need a AFC spring? the 60lbs yes.. the 4k GSK yes.. for fueling purposes. Anything else im missing? looking for about 400HP at wheels should put torque close to 700?
12- 60lb Intake & Exhaust Valve Springs 89-98 12V Dodge Cummins
$110.00
4K GSK RPM Governor Spring Kit 94-98 Dodge 12 Valve Cummins
$115.00
AFC Spring Kit 94-98 Dodge 5.9L 12 Valve Cummins Diesel
$35.00
MBRP DAL401 94-02 Dodge Cummins Aluminized 4" Turbo Downpipe
$105.72
Dodge 5.9L 12 Valve Cummins Killer Dowel Pin KDP Repair Kit
$105.00
94-98 12 Valve Dynomite Diesel 75hp Stage 2 Injectors DDP2
$569.05
Sub-Total: $1,065.77
Old Feb 26, 2011 | 06:25 PM
blacksmoke82's Avatar
save yourself some money an build your kdp kit. buy the crank seal an timing gear cover gasket an build your own tab to hold the dowel pin in. my uncle bought one an wished he didnt after he saw how i did mine saved atleast $50
Old Feb 26, 2011 | 06:35 PM
Default kdp
Can you enlighten me... What's a kdp?.. Also any tips for making the plate for dowel pin?
Old Feb 26, 2011 | 07:48 PM
sjcoan's Avatar
KDP is the dowel pin, Killer. Dowel. Pin. named b/c iot can kill your engine
Old Feb 27, 2011 | 10:24 AM
Default turbo upgrade
Any input on a turbo upgrade? The buildup is moderate mods.. Looking for the 400-750 hp range eventually. Would like a turbo that can run with the 75hp injectors, but will really shine if I ever go to 140hp/ 90 hp injectors...
Old Feb 27, 2011 | 12:33 PM
12valvetater's Avatar
400-750horse? Thats a big range.
Old Feb 27, 2011 | 01:05 PM
94 12valve's Avatar
400hp and 700 ft/lbs is what he is after ... or 400 hp on fuel and 750 on a good ole shot
Old Feb 27, 2011 | 06:33 PM
monster12valve's Avatar
a 62/65/12 would work nice for what u describe
Old Feb 27, 2011 | 07:01 PM
madmikeismad's Avatar
Originally Posted by brianjbeach85
Hey guys,
12- 60lb Intake & Exhaust Valve Springs 89-98 12V Dodge Cummins YES
$110.00
4K GSK RPM Governor Spring Kit 94-98 Dodge 12 Valve Cummins YES
$115.00
AFC Spring Kit 94-98 Dodge 5.9L 12 Valve Cummins Diesel USE STOCK GOVERNOR SPRING FREE
$105.72
Dodge 5.9L 12 Valve Cummins Killer Dowel Pin KDP Repair Kit UP TO YOU ON HOW YOU DO IT
$105.00
94-98 12 Valve Dynomite Diesel 75hp Stage 2 Injectors DDP2 DDP IS WAAAAY OVER PRICED. GO SDX - OR CONTAGIOUS DIESEL (CHEAPER AND REALLY GOOD)
$450 -550, any size
Answers in bold, saves 80 bucks right there. I don't even know what to recommend for a turbo to only get you to 400hp . But a 62mm is a well proven turbo.
Old Feb 27, 2011 | 09:54 PM
Nitrous is for wussies
