How do I get more psi out of the 1993 6.5?
Old Feb 26, 2011 | 08:00 AM
chevyracing's Avatar
Default How do I get more psi out of the 1993 6.5?
I was just wondering if when i turn up my pump will it give me more boost or is there something else that i can do to acheive more boost. This is my first diesel truck so all the help i could get would be great.
Old Feb 26, 2011 | 01:12 PM
Woody35's Avatar
yeah it will plus you need to get a mechanical wastegate like the turbomaster or make one yourself for more control
Old Feb 26, 2011 | 02:12 PM
where would i get a turbomaster?
how do i make one myself?
Last edited by chevyracing; Feb 26, 2011 at 02:12 PM. Reason: Automerged Doublepost
Old Feb 26, 2011 | 07:07 PM
pipelayer4777's Avatar
Heath diesel makes a nice one but I made mine for about $20. The Heath is $150 or so. Crazy has a link to someone that made one and I followed it and it surely works. I have a 53 lb spring on mine and get 12 psi boost WOT/ 14 psi peaks at once in a while. I will get the link and shoot it over to ya.
Old Feb 26, 2011 | 09:19 PM
Crazy's Avatar
here the link
the only thing did was go with the #68 spring the # 49 was to weak it just Ace hard ware # in hardware draw #er spring was like 3 3/4 long x 1 "
Make Your Own Mechanical Wastegate Controller
Old Feb 27, 2011 | 07:52 AM
I will go and try it. Thanks.
Old Feb 27, 2011 | 07:47 PM
2MuchJunk's Avatar
Your 93 will already have a mechanical waste gate. All you have to do is shorten the rod between the waste gate arm and the spring. If you really want do it right you can get a turnbuckle nut. Cut the rod in half and remove a small section of it. Then thread each shorter piece you have one left hand and one right then you can adjust it till you get the right psi.
old chevy
Sep 2, 2015 08:42 AM
glasspack
Jul 29, 2015 11:04 AM
klein444
Feb 21, 2015 10:33 AM
Levis95
Jan 11, 2015 01:54 AM
bdemutis
Nov 28, 2014 08:16 PM
