What trans is this?
Old Feb 25, 2011 | 11:35 PM
Chevy72's Avatar
Default What trans is this?
Trying to figure which auto trans I've got. Can anyone tell me some info on how to id my trans. I bought a 91.5 i/c motor and it came with an automatic attached and I don't know much about these autos. it's a 4x4 with a np205. Thanks
Old Feb 26, 2011 | 06:52 AM
90cummins's Avatar
if it has O/D then it is a 518. if it doesn't then it is a 727. if yours is i/c then i would guess it is the 518 with O/D. good luck
Old Feb 26, 2011 | 12:57 PM
Chevy72's Avatar
Hey thanks a lot. I checked the shifting on it and seemed to be a three speed.... Is the o/d electronic or manual (i.e. does the shifter have 1 2 3 d or 1 2 d and a button on the shifter?) I don't have the truck, just engine and trans so I can't check my self. there are a few electrical connections on the trans, not sure how much electronics would run the 727.
Old Feb 26, 2011 | 05:19 PM
90cummins's Avatar
the overdrive on the 518 will come automatically if the tps works right, but does have a button you can press to turn it off.
Old Feb 26, 2011 | 08:46 PM
crazy clem's Avatar
the 518 has an overdrive scabbed on to it where the tail shaft or coupler to the transfer case should be. mine has two electrical plugs on the shift linkage side. if you are going to use this combo in another make you can make the od activate via a manual switch.
Old Feb 26, 2011 | 11:03 PM
Chevy72's Avatar
Hey guys thanks a lot for your help. I guess i have the 518. i'm not gonna put it in anything, I was trying to figure out what it was so I can sell it. How much do you think a 518 with only 80k on will go for?? Thanks again for helping me out
Old Mar 22, 2011 | 06:08 PM
cumminssmokin30055's Avatar
Default 518 Transmission
Do you still have the 518 transmission if so how much and where you located
Old Mar 22, 2011 | 09:32 PM
snowboard3r411's Avatar
haha i need your 518 but cali is to far away
Old Mar 23, 2011 | 08:38 PM
Chevy72's Avatar
Sorry guys but I just sold it!!! I wish i had known I would have made you guys a deal. Sorry about that!
Old Mar 25, 2011 | 08:58 PM
lilsixcylinder's Avatar
would a 92 d250 still have the 518 auto?
would a 92 d250 still have a 518 auto?
Last edited by lilsixcylinder; Mar 25, 2011 at 08:58 PM. Reason: Automerged Doublepost
