stock head bolt trick?
Old Feb 25, 2011 | 03:04 PM
dipapadakis's Avatar
Default stock head bolt trick?
i was told by one of the bigger diesel guys in my area to get brand new headbolts and one at a time take them out put in a new one and torque them first to 100-115-120-125-130-135-140-145-150-155 waiting 30 minutes after you torque them down every 5 lbs for allowing them to cool and he said hes seen strucks hold 800 hp on the stock ones torqued down like this has anyone heard of this??? i really dont want to loose a bolt in my head..... thanks
Old Feb 25, 2011 | 03:39 PM
tower_ofpower's Avatar
anyone else smell something funny? i've heard of moderately over-torqueing your head bolts as an alternative to studs if you arent going to running anything over 50 psi and more typically, 40 and below. Plus i was always under the assumption steady, continuous pressure while torquing is the best practice for any kind of torque. ever torque something to say... 150 foot pound with a nice steady pull? bump the torque by 5-10 ft pound and it'll click on your first pull with no head movement. once the bolt "rests" you then have to overcome the friction of all the threads and the surface area of the bolt heads shoulders. any torque to yield, or torque in increment specs i've seen jump in at the least 20-25 foot pound increments. now, initial torque of 50 to 100 following suggested pattern letting it "settle" then doing the final torque steady, constant pull would yield the most accurate results. atleast IMO
Old Feb 26, 2011 | 10:33 AM
1978skidootnt's Avatar
Yeah torquing in 5 pound increments is not going to do anything but stress the bolt a number of times. Now if you wanted to torque to 155 start at 100 then 125 then 155 for example. By doing it in 5 pound increments you are turning you bolts into torsion springs in a way to put a mental image in your head.
Old Feb 27, 2011 | 09:46 PM
thanks and should i use arp ultra torque lube or regular oil
Old Feb 28, 2011 | 07:08 AM
monster12valve's Avatar
arp lube. less friction
800 on head bolts is impossible to do reliably. i have heard of a truck with 650 on torqued head bolts...but 800 reliably...
Last edited by monster12valve; Feb 28, 2011 at 07:08 AM. Reason: Automerged Doublepost
Old Feb 28, 2011 | 09:36 PM
Bolt torqueing lube is made for the job why not use it?
wannadrag
May 25, 2015 03:07 PM
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
Vmason
Jan 21, 2015 11:33 PM
Adam65
Jan 9, 2015 11:50 PM
NiNjAassasin545
Dec 2, 2014 11:40 PM
