Turbo ?
Old Feb 25, 2011 | 02:08 PM
joediesel's Avatar
Default Turbo ?
building engine Sdx 5x14 no plate afc mods 4k rev spring 60lb valve springs Mack plug 191dv marine pistons 12mm head studs
What turbo should I go with any good ideas ?
Old Feb 25, 2011 | 02:15 PM
ntallent's Avatar
what kind of budget are you lookin at
Old Feb 25, 2011 | 02:19 PM
joediesel's Avatar
Default Turbo ?
Well not big enough for twins that's for sure
Old Feb 25, 2011 | 04:34 PM
97CumminsDiesel's Avatar
66mm range possibly? Or would that be too much? I've heard of trucks in the 700 range running that size still
Old Feb 25, 2011 | 05:56 PM
madmikeismad's Avatar
a 66 has potential for 750 or so. I've heard the 68 spools like a 64, and pushes like a 71.
I'm getting mine from Chris at ED. We've been talking a couple weeks now about the best turbo for my application. He'll set you straight.
Old Feb 27, 2011 | 12:49 AM
12valvetater's Avatar
What do you want to do?
Old Feb 27, 2011 | 11:17 AM
joediesel's Avatar
Default Turbo ?
Well I'll have to drive it about 30 miles a day other then that have fun with it
Old Feb 27, 2011 | 12:31 PM
Power range? Straight stick, auto? Do you want horsepower or torque?
Old Feb 27, 2011 | 01:37 PM
joediesel's Avatar
Default Turbo ?
Good to auto billet tc and input shat I'm after hp
Old Feb 27, 2011 | 06:51 PM
If you are after power only, no towing, then you could go bigger, like a 475 or 78 as a single if you want it somewhat streetable, or hang one of those under a 62 for a set of compounds for a little better street manners.
It all depends on your overall goal. How much power are you looking to make? What exactly do you use the truck for?
