No power, no codes?
Old Feb 24, 2011 | 08:59 PM
PwrStroked's Avatar
Default No power, no codes?
I got a 04 6.0 the truck is slugish as hell, the turbo is spooling up just makin no power. I checked the fuel pressure, the heads, injectors everything i knew to check. No codes are being thrown so im at a point where i dont got a clue what to do. Any ideas guys?
Old Feb 24, 2011 | 10:11 PM
ntmdtr3fan's Avatar
Throttle postion switch? Or possible vanes stuck in turbo? Had a similar problem wiht my truck. Turbo spooled to 30 sometimes and otehrs to less then 10. Also found that my TPS was going south. It would take 5 miles to get upto speed ( 65 mph) it seemed. Oh and it didnt throw a code for the TPS.
Old Feb 24, 2011 | 10:38 PM
PwrStroked's Avatar
Any way i can check the TPS?
Old Feb 25, 2011 | 07:40 AM
Mdub707's Avatar
What was your fuel pressure and are you checking it while driving, not just idling in the driveway?
Old Feb 25, 2011 | 08:10 AM
MUDSTROKIN''s Avatar
Any hard starting problems hot or cold?
Old Feb 25, 2011 | 12:17 PM
PwrStroked's Avatar
About 55 psi on the fuel at WOT, its cranked fine so far
Old Feb 25, 2011 | 12:56 PM
Mdub707's Avatar
No boost gauge? What's it reading? Hard to say without some diagnosis here. When's the last time the oil was changed or the fuel filters? When's the last time the EGR valve was looked at on it?
Old Feb 25, 2011 | 02:57 PM
bobfbigman's Avatar
did you check the boots on the cooler tubes, they can and will pop off or even split, did this happen suddenly or has it been getting worse over time
Old Feb 25, 2011 | 07:31 PM
PwrStroked's Avatar
Egr valve was checked yesterday and it was clean, the oil filters are a month old and the fuel filter is about week and half old. I don't have boost gauge so Idk about the boost. This happened suddenly and that's what's got me stumped,I checked all the common things
Old Mar 1, 2011 | 06:37 PM
gamaliel's Avatar
Something similar happen to me and it was the hose that conects to the turbo.
May 10, 2015 10:57 PM
explorer197143
Dec 28, 2014 01:14 PM
