Off Roading Diesel Discussions of Off Roading , Set Up , Designs , Practices , Techniques , Tips Including Trail Riding , Rock Climbing , Mud Bogging And More
Converting 2wd to 4wd?
Old Feb 24, 2011 | 08:25 PM
jasoncooperpcola's Avatar
Default Converting 2wd to 4wd?
How hard is it to convert a 96 2500 Sierra that is 2wd to 4wd? I remember seeing something on tv that bolts to the transmission in place of the tailpiece that acts as a transfer case, but i cant find it. Other than that is it just as simple as bolting on a new front end or is it more complicated?
Old Feb 24, 2011 | 09:43 PM
EasternAggie's Avatar
Front end, transfer case, driveshaft. Thats my guess.
Old Feb 25, 2011 | 06:27 AM
DieselCrawler's Avatar
on a chevy is is harder unless you are converting to a solid front axle. then u can buy the kit from ORU and bolt it in sorta.....
Old Feb 28, 2011 | 06:08 PM
bluedieselram's Avatar
most of the time is cheaper to just get another truck.but to change 2wd to 4x4 your gonna need new tranny,t case,new front end,driveshaft & a couple of wires for the mother pump not trying to talk you out of it but unless you have an extra truck to drive while you do the change youd probaly be better off just buying a 4x4
Old Feb 28, 2011 | 10:26 PM
Just depends on how much you like your current truck
Old Mar 1, 2011 | 07:38 AM
rockymtn's Avatar
I've converted three trucks from 2 to 4 whl drive and it's not that hard. A donor truck, Welding skills, torch and grade 8 bolts. On the two older chevy's I did it also required a small section of the floor pan above the transfer case removed and I cut a little larger piece from the donor truck and bolted it in as a removable cover over the transfer case.
Contrary to many stories you hear it is not a bolt on job although on the chevy's there were a lot of common holes between the two frames. If you have above average skills with metal, I say go for it.
Flikkie2001
12
Aug 29, 2015 10:03 PM
twinboys
Feb 18, 2015 06:55 PM
mw1095mw
Jan 4, 2015 11:06 PM
Gman30
Dec 27, 2014 12:46 PM
Machinist
Dec 5, 2014 01:06 AM
