Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
2008 FPP Street Diesel Rules
Old Dec 2, 2007 | 12:01 AM
TCU Fan's Avatar
Aaron
Default 2008 FPP Street Diesel Rules
USA-EAST SLED PULLING, INC.
STREET LICENSED DIESEL 4X4 TRUCKS
2008 RULES AT FULL PULL PRODUCTIONS' PROMOTED EVENTS
1. THIS IS AN OPEN STREET 4X4 TRUCK CLASS AVAILABLE TO CURRENTLY LICENSED OWNERS OF TRUCKS THAT ARE LEGAL FOR HIGHWAY USE. IF YOUR TRUCK IS STREET LEGAL AND IS BUILT TO THE RULES SET FORTH HEREIN, YOU CAN ENTER THIS CLASS. REGISTRATION PAPERS ARE REQUIRED TO PROVE THAT THE TRUCK IS LICENSED FOR STREET USE. A LICENSE PLATE WITH A CURRENT STICKER TAG IS REQUIRED TO BE AFFIXED TO THE TRUCK. REGISTRATION PAPERS AND LICENSE PLATE AND STICKER TAG MUST MATCH. IF APPLICABLE, A CURRENT INSPECTION STICKER IS REQUIRED. TRUCKS MAY BE HAULED TO THE PULL.
2. WEIGHT CLASS IS 8000 POUNDS. NO WEIGHT BRACKETS OR HANGING WEIGHTS ALLOWED ON FRONT OF VEHICLES. WEIGHTS MUST BE IN TRUCK BED AREA ONLY AND SECURELY FASTENED OR CONTAINED SAFELY THEREIN. NO WEIGHTS ALLOWED UNDER HOOD OR IN THE WHEEL WELLS. NO WEIGHTS MAY BE SUSPENDED UNDER THE BODY/CHASSIS OR BEHIND PANELS/PARTS. WEIGHT CLASS MAY BE INCREASED AT THE OPTION OF THE HEAD OFFICIAL, BUT MAY NOT BE DECREASED.
3. ONLY SINGLE TURBO CHARGERS ARE PERMITTED. THE TURBO INDUCER MAY BE NO LARGER THAN 2.6 INCHES NATIVE IN DIAMETER AND WILL BE CHECKED AT THE OFFICIAL’S DISCRETION WITH CALIPERS or A PLUG MEASURING 2.650. NO BUSHING OF THE INDUCER IS PERMITTED. FAILURE TO ALLOW FOR TURBO INSPECTION AND MEASUREMENT WILL RESULT IN IMMEDIATE DISQUALIFICATION WITHOUT A REFUND. ANY TRUCK DISQUALIFIED FOR THIS REASON WILL BE REQUIRED TO UNDERGO A COMPLETE TECH INSPECTION, INCLUDING TURBO MEASURING, PRIOR TO ANY FURTHER PARTICIPATION. ABSOLUTELY NO REFUNDS FOR ANY ILLEGAL TURBO FOUND AFTER THE PULL. NOTE: IF YOUR TRUCK RUNS CONSISTENTLY IN THE TOP THREE PLACES – YOU WILL BE CHECKED!!!
4. ALL TIRES MUST CARRY A D.O.T. NUMBER ON THE SIDEWALL. NO CUT, ALTERED OR SHARPENED TIRES. TRUCKS WITH DUAL REAR WHEELS MAY ENTER AND RUN IN THIS CLASS BUT TIRES MAY NOT EXTEND BEYOND THE OUTER EDGE OF THE FACTORY FENDER WELL. TRUCKS USING DUAL REAR WHEELS MUST HAVE A FACTORY BED WITH FACTORY FENDER WELLS. NO STUDDED TIRES, TIRE CHAINS OR ANY TIRE NOT SPECIFICALLY INTENDED FOR STREET USE ARE PERMITTED.
5. FRONT BUMPERS MUST BE UNALTERED FACTORY STOCK. NO WEIGHTED FRONT DEVICES ARE PERMITTED - THIS INCLUDES BUT IS NOT LIMITED TO: HOMEMADE BUMPERS, BRUSH GUARDS AND WINCHES. LOWER BRACKETS (ONLY) FOR SNOW PLOW FRAMES ARE PERMITTED SO LONG AS NO MODIFICATIONS THAT WOULD ADD WEIGHT ARE DETERMINED. AN UNALTERED DECORATIVE BRUSH GUARD MAY BE PERMITTED AT THE OPTION OF THE HEAD OFFICIAL. A TRUCK IS PERMITTED TO COMPETE WITHOUT A FRONT BUMPER.
6. THE HITCH POINT WILL BE FROM THE REAR BUMPER ONLY OR FROM A “REESE TYPE” HITCH ON A LEVEL PLANE WITH THE POINT OF ATTACHMENT TO THE TRUCK’S FRAME BEHIND THE PUMPKIN OF THE REAR END. NO OTHER TYPES OF HITCHES ARE PERMITTED. HITCH POINT MAY NOT BE MORE THAN 26" FROM GROUND. HITCH POINT MUST BE HORIZONTAL – PARALLEL TO THE GROUND. NO ANGLED, LEVER, PIVOT, AXIS OR OTHER TYPES OF ‘TRICK’ HITCHES ARE ALLOWED AND THE HITCH MUST BE STATIONARY IN ALL DIRECTIONS. THE HOOK POINT MUST BE THE FURTHEST POINT TO THE BACK OF TRUCK. HOOK POINT MUST BE PAST THE BED OF THE TRUCK IF THERE IS NO BUMPER, OR PAST THE END OF THE BUMPER. SHORTENING OF THE BED IN ORDER TO SHORTEN THE HOOK POINT IS NOT PERMITTED. EACH TRUCK DRIVER MUST SUPPLY A TWISTED CLEVIS WITH A HOOKING HOLE A MINIMUM OF 3.5 INCHES ACROSS.
7. NO ALUMINUM ENGINE BLOCKS ARE PERMITTED UNLESS O.E.M. NO OPEN HEADERS WILL BE ALLOWED. PUMP DIESEL IS THE PRIMARY FUEL PERMITTED. ABSOLUTELY NO ALCOHOL, NITROUS OXIDE, PROPANE OR OTHER OXYGEN EXTENDERS. HEADERS ARE APPROVED. APPROVED CROSS BOLTS - NEAREST TO THE CHARGER ARE REQUIRED IF NO MUFFLER IS USED. NO SUPERCHARGERS ARE ALLOWED. ENGINE SWAPS BETWEEN MANUFACTURERS ARE NOT PERMITTED. ENGINE MUST HAVE BEEN AVAILABLE IN 1 TON OR LESS PRODUCTION TRUCK.
8. ANY TRUCK THAT IS RUNNING OVER 4500 rpm IS REQUIRED TO HAVE PROPERLY INSTALLED DRIVESHAFT LOOPS AS WELL AS APPROVED CROSS BOLTS IN THE EXHAUST SYSTEM. TRANSMISSION MUST MEET PRO-STREET RULES. A TELL-TALE TACHOMETER or A COMPUTER DATA LOG MAY BE REQUIRED ON THE TRUCK (AT OWNER’S EXPENSE) IN ORDER TO PROVE THAT THE ENGINE IS RUNNING UNDER 4500 rpm AND THAT THE SAFETY EQUIPMENT IS NOT NECESSARY ON THAT TRUCK.
9. EXHAUST MAY NOT EXIT TO THE SIDE OF THE VEHICLE (TOWARDS THE GRANDSTAND AREA) AND MAY NOT EXIT STRAIGHT DOWN TOWARD THE TRACK. TURNOUTS ARE PERMITTED SO LONG AS APPROVED CROSS BOLTS ARE IN PLACE WITHIN THE EXHAUST SYSTEM.
10. DUALLIES USING GASOLINE AS FUEL AND/OR A STREET LICENSED HEAVY GASOLINE TRUCK THAT CANNOT MAKE WEIGHT FOR THE STREET LICENSED GASOLINE CLASS MAY ENTER WITH PERMISSION OF THE HEAD OFFICIAL. THIS IS A COURTESY EXTENDED TO LOCAL COMPETITORS THAT WANT THE OPPORTUNITY TO PARTICIPATE IN THEIR HOME TOWN EVENT AND IS NOT TO BE CONSTRUED AS OPENING THE CLASS TO GASOLINE TRUCKS.
11. SUSPENSION MUST HAVE A MINIMUM OF TWO INCHES OF DOWNWARD MOVEMENT AT ALL TIMES. NO BLOCKS ARE ALLOWED BETWEEN AXLE HOUSING AND TRUCK FRAME THAT WOULD RESTRICT THE NECESSARY TWO INCHES OF MOVEMENT. LIFT KITS ARE ACCEPTABLE. NO SOLID SUSPENSIONS ARE PERMITTED.
12. TRUCK MUST BE STOCK IN APPEARANCE. FLOOR IN BED MUST BE SOLID. THE WHEELBASE MAY NOT BE CHANGED FROM ORIGINAL MANUFACTURER. WOODEN FLATBEDS ARE PERMITTED WITH SINGLE REAR WHEELS.
13. TRANSMISSION & TRANSFER CASE MUST BE O.E.M. AND AVAILABLE IN ONE TON (OR SMALLER) PICK-UP TRUCKS.
14. DRIVER’S WINDOW MUST BE ROLLED COMPLETELY UP WHILE COMPETING. DRIVERS ARE URGED TO WEAR A SEATBELT or SHOULDER HARNESS AND A MOTOR SPORT TYPE HELMET WHEN HOOKED TO THE SLED. NO PASSENGERS ARE PERMITTED AT ANY TIME.
15. A CURRENT AND VALID 2008 MEMBERSHIP WITH THE USA-EAST SANCTIONING BODY IS REQUIRED ONLY IN ORDER TO COLLECT POINTS. NO MEMBERSHIPS ARE REQUIRED IN ORDER TO ENTER AND PARTICIPATE.
__________________
Old Dec 2, 2007 | 10:30 AM
LOGANSTANFORTH's Avatar
ALOT of stupid rules in there.........if they let gas trucks run.........id put a turbo on a 5.4 ford in a superduty with a 6 speed manual.......came that way factory with a 6 speed manual.......and watch alot of those diesel boys start crying.......and why cant a truck run a factory supercharger that engine was sold with......the 5.4 in the spoken of superduty........a turbo feeding the factory blower.........never says how many stages of forced induction you can have, just says one 2.6 wheel charger..............only rules that kills it is the no supercharger rule which is unfair...........
rule #2, id load the front frame rails with lead....
rule #4, its a joke, 75% of the dually's out there dont have factory beds, but they sure let single tire trucks run homemade flatbeds......
rule #7, are they allowed to run industrial and Ag blocks in cummins powered trucks since they are "technically" available in 1 ton or less trucks.....
rule #9, i love this rule, lets shoot the big chunks of turbo away from the truck instead of into the track...............
rule #13, can we run single speed kits in NP205's all they say is the case must be OEM.....
not barking at you, i just think its fun to destroy someones rules by thinking of ways to cheat.......
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
