power steering pump leaking
Old Feb 23, 2011 | 11:19 AM
24vcumminscowboy's Avatar
Default power steering pump leaking
hi i replaced my power steering pump last sunday second time ive done this in under a year but any way got it all hooked up and bled drove my pickup home came out the next morning pump was bone dry filled it up and watched a steady drip off the bottom of the pump it constantly drips i checked hoses the return hoses need replaced but it was dry around the return hoses i replaced the o-rings on the power hose although im not to sure about the bigger o-ring and where it goes still leaks anyway im running out of ideas hoping someone can shed some light on the subject when i replaced it before i never had this problem anyway thanks for reading
Old Feb 23, 2011 | 11:25 AM
GuyWithA24Valve's Avatar
Sorry I can't help ya out but my power steering pump is leaking in the same spot.
Old Feb 23, 2011 | 11:40 AM
ya i top mine off and it will be bone dry in 3-4 hours im using a quart of fluid everyday and dont have another vehicle to drive so i have to get this fixed asap
Old Feb 23, 2011 | 01:22 PM
are there any orings that you need to lubricate before you run it for the first time? Kinda like a rubber rear main seal in a motor, you have to lubricate it before you start it so you don't burn it up and cause it to leak right away. Just a thought
Old Feb 23, 2011 | 02:26 PM
i think i found my problem theres like a little drian plug on the back of the pump and it only had a crappy plastic plug but my old pump never had one and it constantly leaks so im going to check my old pump and see if it has a plug for it
Old Feb 23, 2011 | 03:20 PM
Mine looks like its leaking from around the shaft itself.
Old Feb 23, 2011 | 04:46 PM
that sounds like a seal to me my buddy has got a 98 12 valve that has that problem and its the seal on the pump
Old Feb 23, 2011 | 06:50 PM
thats what i thought. Sucks cause mine only has 55,000 miles on it
Old Feb 23, 2011 | 07:14 PM
ya that does suck mines on its third but im up to 184,000
Old Feb 23, 2011 | 07:50 PM
Is the pump itself made by Wabco? I noticed mine says that where it mounts to the gear case
