E-brake
Old Feb 23, 2011 | 02:42 AM
01_cummins's Avatar
Default E-brake
so on an 01 ram 2500 with disk rear brakes im sure that each tires holds the truck a certain way when the parking brake is engaged.... as in the drivers side holds it from rolling fwd when parking brakes engaged but i can't find anywere side holds the truck from rolling witch way. has anybody else had this issue? or is more expierienced with this? thanks
Old Feb 23, 2011 | 10:49 AM
banditsdiesel's Avatar
im not so sure it matters a parking brake applies just as a typical drum brake would, evenly so that both side hold in both directions. i have never heard someone say that one holds it one way and the other holds the other way. that just honestly doesnt make much since to me.
Old Feb 23, 2011 | 05:03 PM
thebullet83's Avatar
if they're set up the same as drums, they hold both ways. but that being said, i worked on a car that had a mechanical caliper thing and didn't have shoes. i gripped the rotor with pads.
Old Feb 23, 2011 | 07:52 PM
tiremann9669's Avatar
I have a VW like that.
Old Feb 23, 2011 | 07:58 PM
mysterync's Avatar
It has a drum-in-hat style parking brake design and utilizes an independent set of shoes to park the vehicle. It works both ways, if it's not working both ways It's a pretty simple fix!
Old Feb 24, 2011 | 10:49 PM
01_cummins's Avatar
they aren't working both ways...so im not sure what to do about it any ideas?
Old Feb 25, 2011 | 12:36 AM
mysterync's Avatar
First thing to do would be check the adjustment, or perform the adjustment for that matter with the following procedure.
Exactly How the Factory Manual shows to adjust.
ADJUSTMENT
NOTE: Tensioner adjustment is only necessary when the tensioner, or a cable has been replaced or disconnected for service. When adjustment is necessary, perform adjustment only as described in the following procedure. This is necessary to avoid faulty park brake operation.
1. Raise the vehicle.
2. Back off the cable tensioner adjusting nut to create slack in the cables.
3. Remove the rear wheel/tire assemblies. Then remove the brake drums.
4. Verify the brakes are in good condition and operating properly.
5. Verify the park brake cables operate freely and are not binding, or seized.
6. Check the rear brake shoe adjustment with standard brake gauge.
7. Install the drums and verify that the drums rotate freely without drag.
8. Install the wheel/tire assemblies.
9. Lower the vehicle enough for access to the park brake foot pedal. Then fully apply the park brakes.
NOTE: Leave park brakes applied until adjustment is complete.
10. Raise the vehicle again.
11. Mark the tensioner rod 6.35 mm (1/4 inch) from edge of the tensioner.
12. Tighten the adjusting nut on the tensioner rod until the mark is no longer visible.
CAUTION: Do not loosen, or tighten the tensioner adjusting nut for any reason after completing adjustment.
13. Lower the vehicle until the rear wheels are 15 - 20 cm (6 - 8 inch) off the shop floor.
14. Release the park brake foot pedal and verify that rear wheels rotate freely without drag. Then lower the vehicle.
The Next Step would be verify the condition of the rear rotor and Inner parking drum, if there's signs of wear it's a good time to replace. Then determine if new parking shoes are needed. Verify the cables have free movement once disconnected. If you cant find anything sometimes the best thing to do is figure a complete parking brake rebuild in which you would order the Parking brake hardware kit, Parking brake shoes, and Rotor's and cables if needed. Another note, If there is any binding in the pads (the brake pads *service brakes*) between the pad and bracket, Clean until pads move freely to prevent a soft or low pedal. Also verify the caliper moves freely on it's slides. Slides are available at an auto parts store very cheap. These last two items are the probably the biggest problems with disc brake systems and cause frequent and expensive repairs if not fixed correctly.
The following is the instructions on replacing the rear shoes, as you can see their vague...for the fact it's a simple process. If you were to need help diagnosing your brakes any further or in the repair you could post here again and folks will be glad to help!
REMOVAL - REAR DRUM IN HAT PARK BRAKE SHOES - 2500/3500
1. Raise and support the vehicle.
2. Remove the tire and wheel assembly.
3. Remove the disc brake caliper
4. Remove the disc brake rotor
5. Lockout the Harking brake cable.
6. Disengage the park brake cable from behind the rotor assembly to allow easier disassembly of the park brake shoes.
7. Disassemble the rear park brake shoes.
INSTALLATION - REAR DRUM IN HAT PARK BRAKE SHOES - 2500/3500
1. Reassemble the rear park brake shoes.
2. Release the parking brake cable.
3. Install the disc brake rotor.
4. Install the disc brake caliper, .
5. Install the tire and wheel assembly.
6. Lower the vehicle.
Hope this get's you started, As i said, if you need help just let us know!
Just read what I posted and the adjustment is actually for the drum style. Most drum in hat styles adjust the same and can be done manually if the auto adjust isn't working. Once apart you'll find it simple to adjust them
Old Feb 25, 2011 | 11:49 AM
01_cummins's Avatar
part of my problem is i have way to much slack in my cable there is no pressure on my pedal till 3/4 of the way to the floor
Old Feb 25, 2011 | 12:35 PM
mysterync's Avatar
Adjust the tensioner on the driver side frame rail till the tension is more acceptable.
Hogridenfool
Nov 20, 2017 04:37 PM
weatherby
Aug 31, 2015 08:04 PM
Turbo67
Jul 25, 2015 02:26 PM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
yams
Nov 29, 2014 09:25 PM
