Is getting rid of VE pump worth it?
Old Feb 22, 2011 | 08:48 PM
fatirishguy's Avatar
Default Is getting rid of VE pump worth it?
Should I get a holly black or airdog or fass. Does this really help with power and MPG. I was told i have the bigger injectors but i dont know how to check for sure, will there be a stamp on the injector if I pull one out. my deisel mech said I should not need it on this truck.91.5 d 250. pump tweekd, dennt t pin. bhaf, 4 to 6 exhaust. all gauges up and running.
Old Feb 22, 2011 | 10:24 PM
dieseldawg's Avatar
hahaha getting rid of ve pump???? you need to sell your truck and buy a honda
Old Feb 22, 2011 | 11:56 PM
big bad diesel 416's Avatar
Site Sponsor
I think what your meaning is should you get rid of you mechanical lift pump?
not your VE > which is your injection pump the truck wont run with out that
Theres no real way to check unless there branded they could be anything from SDX to DDP to 370's give me the numbers off them
do you have an intercooler? being you say its a 91.5 I would guess so
I would go airdog IMO I have one on all my rigs and sold LOTS of them they work flawlessly and the filtration is awesome not to mention there is NO lack of supply
there is no real reason to get one based on your setup you dont have many big power mods if I were you I would go piston style lift pump they will make up to 300-350HP and there about 300 bucks less than an airdog
Brice
Old Feb 23, 2011 | 05:11 AM
tower_ofpower's Avatar
only thing he could gain from an air dog would be the removal of entrapped air in the fuel in turn make the girl quiet down a DB or two, and when big bad said a "piston pump" he meant the low pressure one. not the one that is meant to feed the P7100 which will blow about every seal you have in your IP. if you look around the site there's multiple threads that have the pump # and what it takes to install one.
Old Feb 23, 2011 | 08:04 PM
Yea, drinking a little to much when i posted. I did mean the mech fuel pump. get a honda really my 2001 makes 605hp and 1234 trq. on the dyno yea im not a diesel guy. by the way thanks big bad diesel.
Old Feb 23, 2011 | 10:18 PM
Site Sponsor
Your very welcome friend!
Old Feb 24, 2011 | 12:45 AM
dieseldawg's Avatar
that must be one fast *** honda!! hahahaha
Old Feb 24, 2011 | 06:30 AM
KD93's Avatar
No, it won't... to a point. It won't make a difference to your mpg's, but as BBD said, it's not until you start getting towards 300+ that you're going to need to upgrade your fuel supply. The VE is capable of sucking it's own fuel down to 0psi, but it's definately not recommended. Even a stock truck would be well served by a low pressure lift pump.
Bigger injectors? Meaning the 9mm bodies? I can't remember when they went to a 7mm....
Old Feb 24, 2011 | 09:28 AM
NadirPoint's Avatar
Default What Do You Mean by All Gauges?
...all gauges up and running.
So what's the fuel pressure doing? Knowing that is always a good place to start with fueling issues.
Old Feb 24, 2011 | 07:16 PM
isspro pyro,boost,tranny temp and 3.5 in tach.
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
moneypitk5
Feb 12, 2015 11:01 AM
B.k. Smith
10
Jan 7, 2015 02:29 PM
