Cold start up
Old Feb 22, 2011 | 05:10 PM
BVFD54's Avatar
Default Cold start up
Is it common for the 94 stock turbo IDI when it is first started to smoke white and run rough? It idles just fine and doesnt smoke after the engine is warmed up to where the temp gauge is just off the cold mark. This truck has new injectors and glow plugs (which I always wait until the wait to start light goes off).
Forgot to mention that the smoke smells like diesel fuel and not sweet like coolant.
Old Feb 22, 2011 | 08:07 PM
Sycostang67's Avatar
White smoke on a cold start is normal, it just hasn't warmed up enough to completely burn the fuel. How rough is it idling though? I have a bad glow plug in mine right now and it shakes pretty good for 10-15 seconds when started cold.
Something for you to try. I have noticed that just because the WTS light goes off, it doesn't mean the plugs are done heating. Watch your battery guage, the needle will dip pretty low while the plugs are heating and come back up when done. Wait for the battery guage to return to normal then try and start it. It may just start a little bit smoother.
Old Feb 22, 2011 | 09:06 PM
BVFD54's Avatar
Well I just replaced a battery in the truck. With one bad battery will that cause the glow plugs not to heat as well?
As for the rough idle when cold ill try to get a sound clip of it. *an after thought*
Old Feb 22, 2011 | 10:13 PM
DieselCrawler's Avatar
could be timing might be a little off.
Old Feb 23, 2011 | 04:53 PM
BVFD54's Avatar
How bad is the timing of the injection pump to do on the IDI? I went to school for diesels but that was for tractors.
Old Feb 23, 2011 | 04:56 PM
where in ohio are you? i went to UNOH in lima. i am sure they could time it for ya if ur close to there. need a special timing meter.
Old Feb 23, 2011 | 06:38 PM
BVFD54's Avatar
I am on the Ohio river... Marietta Ohio, Parkersburg West Virginia. My brother went to UNOH for high performance auto.
Bigredpowerstroke
Aug 14, 2015 10:31 AM
Mike0885
May 27, 2015 12:07 PM
jbutler713
Feb 27, 2015 08:44 PM
ronstop
Feb 26, 2015 09:48 AM
custom7.3
Nov 23, 2014 10:44 PM
