First post and a question
Old Feb 22, 2011 | 12:58 PM
NW_Jim's Avatar
Default First post and a question
Hi, This is my first post here. I usually just lurk and do a lot of searches to find info but can't find the answer I need.
I just go back from our annual trip to the Florence dunes towing our 40 ft toyhauler for the first time since getting a DTT trans installed, installing a PacBrake and a BD tow lock. Finally able to use some of the power the Edge gives me and I pop the Turbo to intercooler hump hose out from under the clamp on a steep grade. Fixed it and it immediately popped out again. I understand the stock ones are not up to snuf and can't handle additional boost much so the question is this - I am looking at two different manufacturers, BD and Mr. Bobs. Mr. Bobs kit appears to have the hump hoses that look like the stock ones, BD's kit does not. Are the hump hoses necessary? Seems like you would want them on a short hose to allow for engine movement. I would prefer to get the BD's since one of my favorite local outfit sells them and I can get them alot cheaper but I don't want to sacrifice anything in the process. Thanks in advance for all suggestions.
Jim
Old Feb 22, 2011 | 01:20 PM
moparious maximus's Avatar
Im surprised you are having boost hose problems with a stock turbo, I thought they would take more than the turbo could make.
One cheap trick to get them to hold a little better is to put an extra set of clamps on, its not as good as aftermarket hoses and clamps but it does do the trick.
Old Feb 22, 2011 | 01:28 PM
NW_Jim's Avatar
Thanks for the advice, there really is not enough room on the turbo side to add another clamp. I want to fix this right. It sucked driving 350 miles with a nasty leak having the EGT alarm going off on every big hill on the freeway.
Old Feb 23, 2011 | 12:40 AM
banditsdiesel's Avatar
i have the mr. bobs on my twin turbo, and see 100 psi of boost on the track with her. i have never blew on off, my twin set on the other hand had the bd clamps and i blew them off the cold pipe more than once. so my suggestion is the mr bobs the quality is much higher and the clamp on much better. and yes you need the hump for expansion and engine twist under a load, not having them can push the turbo side down and force the intercooler connector out, ive seen me do it. the stock ones will handle up to 50 psi usually, but if the truck is high mileage or the boots are extreamely wore 10 psi can blow them out from under the clamp. diesel parts are like most everything you buy quality cost more. go with mr bob you wont be disapointed with them.
Old Feb 24, 2011 | 01:00 PM
NW_Jim's Avatar
Just bought the Mr. Bob's hoses and clamps. I don't like to skimp when it comes to stuff that could keep me from getting home. Just one less thing to worry about.
Thanks everyone,
Jim
Old Feb 24, 2011 | 07:17 PM
Headcase98002's Avatar
The turbo is more than likely blowing oil out the compressor wheel and soaking the boots. you need to rebuild your turbo before putting on the new boots.
Old Feb 24, 2011 | 07:58 PM
NW_Jim's Avatar
Really,
How many miles normally before a rebuild on the stock turbos?
Old Feb 24, 2011 | 08:12 PM
Whit's Avatar
Site Mascot
I have the BD boots , they are great
lil trick puttin em on is use hair spray, nice a slick then it sets up
make sure to wipe the grease of wifes hairspray before ya put it back
Old Feb 24, 2011 | 09:00 PM
My stock turbo lasted about 130K before it started spitting oil out the compressor housing, but everything else was great.
Old Feb 25, 2011 | 02:19 PM
NW_Jim's Avatar
Just pulled the old boots and they are dry as a bone other some minor soot that barely got a paper towel dirty. Boots are really soft and look deteriorated. Glad I have new ones coming. I treat my turbo really well and never shut it down hot. I also run Amsoil exclusively with a Dual Bypass system. The truck also just barely broke 100K.
