'93 F350 IDI- about to turbo - advice
Old Feb 22, 2011 | 09:29 AM
roybatty's Avatar
Default '93 F350 IDI- about to turbo - advice
say Mates :
new guy here to this board . am about to turbo the 7.3 idi - just refreshed heads and gaskets - New ip....gave a fresh paint job to most of the parts I removed - any advice before I put moteur back into cradle ? going with a used ATS system / full size down pipe and will look to set up gauges
cheers in advance
Old Feb 22, 2011 | 09:43 AM
DieselCrawler's Avatar
just bolt it on and go. after putting the turbo on u wil want to turn the pump up about 2 flats to get full usage of the boost.
and unless the cab is off, u will need to set motor in first, then put the turbo on. it is a tight fit back there. before putting the motor in, take a BFH and beat the pinch weld on the cab over to give you more clearance.
Old Feb 22, 2011 | 09:52 AM
roybatty's Avatar
say DieselCrawler:
Cheers for the reply - I anticipated this dynamo install , purchased IP for turbo idi - so should already be advanced fuel setting , no?
cheers:
Old Feb 22, 2011 | 11:39 AM
yea, should be good then.
bigblu
18
May 10, 2015 10:52 AM
Ian Roberts
Mar 23, 2015 12:36 AM
schearer350
Feb 12, 2015 12:27 AM
jrsavoie
Feb 6, 2015 09:44 PM
g.logistics
9
Nov 22, 2014 08:54 AM
