How does the speedometer work?
Old Feb 21, 2011 | 05:57 PM
mikeproeder's Avatar
Default How does the speedometer work?
I have a 1984 f 250 4x4 and my speedometer does not work I pulled the cable out of the transfercase and the gear on the cable looks good and I put a drill to it and the speedometer worked! But I don't u derstand why when I put the cable in the transfer case it will kinda work but not correct then it will go away... Is the gear in the transfer case stripped ? Or am I not installing it right and if anyone has a diagram how the transfercase comes apart so I can replace that gear please help me out
Old Feb 21, 2011 | 08:00 PM
Sycostang67's Avatar
Most likely the drive gear in the t-case is stripped. I believe you only have to remove the tailshaft housing to get to it though.
Old Feb 22, 2011 | 03:12 PM
thats what i was thinking too ill try that and see if it fixes it thanks !
Old Feb 22, 2011 | 08:05 PM
If you can shine a small flashlight in the hole, you may be able to see if the gear is chewed up.
Powerstroke36
Sep 21, 2015 08:32 PM
Strictly Diesel
Strictly Diesel
Jun 30, 2015 06:48 PM
cjgregory
Mar 31, 2015 01:45 PM
wood2turn
Chevy/GMC Duramax 04.5-05 LLY
Jan 1, 2015 07:28 PM
Oct 18, 2014 10:10 AM
