90 1 ton lift and tires.
Old Feb 21, 2011 | 11:16 AM
sitosterol's Avatar
Question 90 1 ton lift and tires.
I have seen a lot of this year with lift and tires but, my question is what will ACTUALLY fit with or with out a lift. my truck is stock as in no lift and stock tires and wheels. i want to put some 35X12.5-16r tires and wheels on it and i was wondering what back spacing and hight i can get with no lift. pretty sure 35's will fit with some trimming but does any one have any pics of it actually being done? if thats the case when i get my 4" lift can i throw 38's on it?
Old Feb 21, 2011 | 01:33 PM
DieselCrawler's Avatar
cant help ya on that body style. but 35's should clear, might need minor fender clearancing and possible spacing out the front bumper some.
Old Feb 21, 2011 | 06:41 PM
stackboy6.9's Avatar
go skyjackers website.theres a tire chart and it shows how big of tires you can go with a lift
Old Feb 22, 2011 | 09:04 AM
sitosterol's Avatar
well the website is telling me i need a 4 inch lift to clear 35's? thats my problem it i can squeek out 38's on a 4 inch lift then i wont be wasting money buying tires next year cause i dont like how small they look with a 4 inch ya know?
Old Feb 22, 2011 | 02:15 PM
dslman's Avatar
well u r pushin it with 35's stock i tried it but the turns r what gonna give u problems! some trimmin of the fender and bumper helps but dont do ant serious muddin or playin around!! it will cost u more!!
Old Feb 22, 2011 | 06:01 PM
sitosterol's Avatar
where to trim though? any pictures? if i bump-stop it should not rub in flex right?
Old Feb 22, 2011 | 06:14 PM
dslman's Avatar
Well u gonna have to trim front bumper if u still have original or move it forward some then trim bottom of front fender at an angle and also plastic fender well or push it back! The rear should clear just no heavy loads or flexing! Sorry I don't have any pic and ur right it shouldn't rub!
Old Feb 23, 2011 | 09:07 PM
is this for a f350 or f250.cus you can easily clear 37s if its a f350.so 38s will fit
Old Feb 24, 2011 | 04:40 PM
sitosterol's Avatar
its a three fifty but its the same problem as buying to small if i get huge ones and they rub ill be effed the same but ill have spent more money.
Old Feb 25, 2011 | 09:40 PM
StrokerDude's Avatar
the 90 F350 I recently bought happens to have 36-14.50-16.5 swampers on it. And it's stock! The key is the backspacing on the wheels. Mine sit in under the truck pretty well, no trimming was done or needed. At full lock turning left only, the tire rubs the spring a little bit, what's weird is that it doesn't always do it but most of the time does.
My real opinion though... I hate the tires on my truck, I think the wheels sit just a touch too far in. I would rather trim the bumper slightly and even the bottom corner of the fender SLIGHTLY than have my tires hit the springs.
If the weather is decent tomorrow, I will take a couple pics to post up.
