LMM Performance Discussion of Chevy and GMC Trucks with LMM Duramax Turbo Diesel Engines Related To Performance And Longevity
LMM Trany cooler lines.
Old Feb 20, 2011 | 10:41 PM
dieseltard's Avatar
Question LMM Trany cooler lines.
Has anyone found a good way to replace the OEM Allison 1000 cooler lines? The stock transmission cooler lines have a section of rubber tubing sandwiched between the metal ends of pipe that go into the transmission and cooler. One of mine is leaking right where the rubber meets the metal. Anyone replaced their stock cooler hoses with braded hose? IF so where did you get it? Thanks.
Old Feb 21, 2011 | 12:28 AM
BriteWhiteRam's Avatar
braided lines are nice and all but overly expensive, all you need is high pressure hydraulic line, and better crimps for the fittings
chevy silverado duramax transmission cooler hoses on eBay.ca (item 180628575140 end time 01-Mar-11 12:56:38 EST) this is the kit I got for my truck, comes with all three lines and complete instructions for install, much better quality than the POS stock lines from GM
Old Feb 21, 2011 | 09:26 PM
dieseltard's Avatar
Thanks for the fix. I'll check it out on ebay.
Old Feb 25, 2011 | 09:09 AM
BLACKDX's Avatar
I just took mine off and went to a local hose shop and they made up new ones using the ends.....
Bighouse
Apr 9, 2015 06:51 PM
bypass-21
Dec 15, 2014 08:52 AM
BubbaDT55
Dec 7, 2014 08:52 AM
Mayhem
Price Quote - Request A Price
Nov 22, 2014 03:04 PM
FlyingDutcman
Oct 28, 2014 04:56 PM
