What would cause my fuel tank to be pressurized?
Old Feb 20, 2011 | 10:39 PM
Smoke 'em's Avatar
Default What would cause my fuel tank to be pressurized?
What wud cause my fuel tank to be pressurized?
Old Feb 20, 2011 | 10:43 PM
Uncle Bubba's Avatar
The roll over valve is clogged and not venting the way it should. There's a whole long thread of mine here someplace with this same issue.
Old Feb 21, 2011 | 07:54 AM
RAW's Avatar
RAW
Are you noticing all this pressure when you take your fuel filler cap off? I'd be looking at the fuel cap if that's the situation.
Could this be what you are thinking about:
https://www.dieselbombers.com/dodge-...el-system.html
Old Feb 21, 2011 | 09:45 AM
moparious maximus's Avatar
Are you positive its pressure? We have had problems with a vacuum building up in the tank, that can cause problems.
Old Feb 21, 2011 | 12:07 PM
Smoke 'em's Avatar
it seems as its sucking air in when i take the cap off, and then diesel vapor comes out
Old Feb 21, 2011 | 01:14 PM
Yea thats a vacuum in the tank, its just not venting right.
Old Feb 21, 2011 | 10:13 PM
Smoke 'em's Avatar
So new cap? or try driving with it loose and see if that fixes it, then a new cap?
Old Feb 22, 2011 | 08:35 AM
RAW's Avatar
RAW
You could try driving around with the cap loose, or off to see if it makes a difference. I will almost guarantee it will though.
Old Feb 22, 2011 | 12:06 PM
Smoke 'em's Avatar
Sweet! I hope that is the problem
Old Feb 22, 2011 | 12:40 PM
Horns's Avatar
Go to the junk yard and get a cap for $5. Imo
