converting to a 5 speed trans need help picking a clutch
Old Feb 20, 2011 | 10:51 AM
farleytc's Avatar
Default converting to a 5 speed trans need help picking a clutch
bought the truck last summer with a supposed rebuilt trans and it went out in january. im getting a 5 speed to put in and need to get new clutch for it. when i got the truck i was told it had 90 hp delivery valves and injectors a 24 valve turbo and a adjustable fuel plate half forward i dont know what kind of hp im running i drove a buddies truck that has 400hp on dyno and mine doesnt seem to have as much power. i dont want to spend $1,000 on a clutch what do you guys think? the trans im getting is out of a 98 12 valve.
Old Feb 20, 2011 | 02:07 PM
blazier18's Avatar
do u haul anything long hauling trips or short? is it just a daily driver? id call south bend or valair and tell them your amount u want to spend and go from there
Old Feb 20, 2011 | 02:46 PM
12valvetater's Avatar
Rigid double ceramic buttons
Old Feb 20, 2011 | 04:26 PM
blazier18's Avatar
he may can get a single disc and be alright
Old Feb 20, 2011 | 06:16 PM
Singles are a waste of money.
Old Feb 20, 2011 | 07:32 PM
blazier18's Avatar
and duals are more than hes wantin to spend
Old Feb 20, 2011 | 08:01 PM
farleytc's Avatar
well ive looked at alot out there i dont do alot of pulling when i do i pull a skid steer total pulling wieght about 9000 lbs. you think a single will hold up to that. and like i said im not gunna add anymore hp although i dont even know what i have now i just know it is alittle more than stock.
Old Feb 20, 2011 | 08:49 PM
captain_stabbin's Avatar
if that's all your using it for, a stock single disk will do just fine
Old Feb 20, 2011 | 08:56 PM
farleytc's Avatar
even with it being over stock hp you think a stock sigle will be good and it will last a while.
Old Feb 20, 2011 | 09:24 PM
heavy hauler's Avatar
I have a south bend single disk rated at 475 hp and like it pretty good. I jumps a little when you have to ride the clutch but itsd great. I drove a friends that had a dual disk and should have spent the extra couple hundred and gotten the dual disk. Just my 2 cents.
