crappy night.. now what?
Old Feb 20, 2011 | 01:45 AM
alwazjeepin98's Avatar
Default crappy night.. now what?
driving home on interstate going 75 all the sudden pops outta gear and no longer will move in forward gears. will go in reverse but have no forward gears? any idea what part went bad in the 5600?
Old Feb 20, 2011 | 07:26 PM
crusty_critter03's Avatar
clutch slave cylinder? in my 03 i pushed my slave thew the fire wall... maybe yours is stuck in the 'clutch disengaged' position... just a random thought... good luck to ya
Last edited by crusty_critter03; Feb 20, 2011 at 07:28 PM. Reason: re-read original post...
Old Feb 20, 2011 | 07:30 PM
mysterync's Avatar
So it will shift, just not move in any direction but backwards? If so, It's for sure an internal issue and running the truck is doing nothing but making things worse. Seriously doubt that it would be shift rail related with how your describing it. Couldnt really understand if you ment it would go IN gear and not move or wouldnt go in any gear but reverse.
Old Feb 20, 2011 | 08:58 PM
captain_stabbin's Avatar
was you just cruising or hauling ***?>
Old Feb 20, 2011 | 09:27 PM
it will sit in gear like it will go in gear but release clutch and wont move. in 6th gear if i push really hard to the right it grinds a little. its not clutch/slave problem reverse works great lmao
Old Feb 20, 2011 | 09:38 PM
mysterync's Avatar
It for sure an internal failure. Avoid running the truck if at all possible to avoid further damage. It's even possible with a manual trans to have a catastrophic failure if parts have "dropped" which would equate to a damaged and unrepairable case. And that leaves you with a healthy core. Until it's disassembled there's no way to know whats causing your problem.
Old Feb 20, 2011 | 10:09 PM
someone said something about the nut coming off? i thought that was only with the 4500 not the 500. if that were to happen what would my trans be doing? same thing it is now? thanks yall
Old Feb 20, 2011 | 10:18 PM
mysterync's Avatar
Nope, sounds like you have a mainshaft issue or a counter shaft issue. NV4500 would loose 5th gear nut and loose 5th gear all together.
Old Feb 20, 2011 | 10:22 PM
yea i lost all gears but reverse
Old Feb 20, 2011 | 10:31 PM
Uncle Bubba's Avatar
I've personally only heard of this happening one time in a 5600 and it was because of power shifting,"no clutch used shifting".
