power steering/brake issue
my dad has an 01 cummins recently started having problems with it pushing fluid out of the cap when he shuts the truck off and and losing some of his braking and power steering and sounds like the power steering is whining in the mist of everythingany help would be great thanks ahead of time
sounds like theres air getting in the system some how i know when i bled my ps pump out the air bubbles would boil out from under the cap and the brakes are run with the ps pump and wont work without ps pump so you might check hoses and such that would be my best educated guess hope this helps
My dad had this trouble on his 1998 24V Cummins and he took it to a place and they said that he was using the wrong power steering fuild. We changed it and it worked fine. I can't remeber what brand they told him to use.
For some reason with Dodges, you have to have the weight off the wheels, when you steer lock to lock, to bleed out the power steering. Otherwise it takes a long time to get the air out. I just recently repaired three trucks and it was the only way to bleed them completely. otherwise the foam came out the pump cap.
1ATony
1A Auto Parts
Jan 5, 2016 12:03 PM
1ATony
1A Auto Parts
Dec 7, 2015 01:09 PM
1ATony
1A Auto Parts
Oct 29, 2015 02:11 PM
big tan snorkel
15
Dec 17, 2014 05:04 PM
