Transmission is starting off in 2nd.
Old Feb 17, 2011 | 10:08 PM
dieseldude848's Avatar
Default Transmission is starting off in 2nd.
Hey guys, my 99 dodge's automatic trans is haveing some issues. It is starting off in second gear, and will not go into 4th gear overdrive, but I can get it to go in 1st manualy putting the selector in 1st. 2nd/3rd are good, and the it does not slip seems real tight. Any ideas to what's going on?
Old Feb 17, 2011 | 10:17 PM
chad83181's Avatar
Codes
Old Feb 17, 2011 | 10:46 PM
blue24valvecummins's Avatar
maybe the governor pressure switch and or sensor or a shift solenoid in the transmission
Old Feb 18, 2011 | 07:56 AM
94dizzyram's Avatar
sounds like transducer in your tranny. had mine replaced and valve body cleaned at dealership about 2 years ago. cost me about 500$ at the stealership.
Old Feb 18, 2011 | 11:46 AM
Smarty=Cummins's Avatar
When was the last time you replaced you trans. filter.
Old Feb 20, 2011 | 01:29 PM
CumminsKid99's Avatar
im having the same problem with my trans. My tranismission is freshly rebuild. i was doing alil research and i found an add talking about shift bands and them needing adjustment i have yet to try but when i do ill let ya guys know
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
SixSpeed
Jan 11, 2015 01:41 AM
W350-4x4
Nov 12, 2014 09:35 AM
TheDirtyDozen
Oct 1, 2014 10:09 AM
